BBCode DatabaseAll custom BBCodes in a dropdown box
BBCode's
kaspir
Re: All custom BBCodes in a dropdown box
Post by kaspir »
dmzx wrote: Jan 18th, '17, 18:46
kaspir wrote: Jan 16th, '17, 08:36 I might have a problem with most of my bbcodes, ever since the 3.2 update many of the helplines have vanished or defaulted to w/e the language variable is I guess. I'm pretty lost on this, any help would be appreciated as many of my bbcodes are broken and it probably has nothing to do with the extension you gave me martin. I'm also posting on phpbb I guess.
To this problem the bbCodes are parsed different in 3.2 and you have to update them in your database. (otherwise they will not display correct)
MMM, I was really trying to avoid editing all of them, I'm not gonna hide it. :)
BACK BURNER! :buigen:
Check out phpBB contributions & extension downloads. :P
dmzx wrote: Jan 18th, '17, 18:46 To this problem the bbCodes are parsed different in 3.2 and you have to update them in your database. (otherwise they will not display correct)
stupid question: how can I update BBCodes (or something else) in my database? I noticed, local url to text is lost in topics, too - after upgrade.
kaspir
Post by kaspir »
Edit: Forget everything I said, I'm totally clueless.. maybe it's because I'm super pissed phpbb has forced this shit onto us.. there I said it. Feels lil betta...
So.. phpbb expects everyone to make changes within their DB tables... WOW I totally DID NOT see that one coming.. hell it didn't even register when I read dmzx post earlier.
Soooooooooo.. @MARTIN! If I haven't annoyed you enough yet...
I said screw ABB3 because I think the author is just gonna ignore me, also not support the custom dropdown bcause it's not part of his ext.
I switched to the DL you gave me; X-BBcode Silk Buttons. Installed.. looking at:
Most codes under customs, look like abbc, so I'm thinking I should just remove them at this point. UNSURE.
Also, when clicked on a username "Select Username", I get this: [username|#008000|bold|2]kaspir[/username] and nothing else in the post.
AND, as for the MOD_CMD you can see.. DM says I should change in DB, phpmyadmin, too easy I guess.
After all this, I have NO posting editor that actually is any good, yet being the keyword. THANKS BB! (sarcasm)
Thank you for your answer, kaspir :)
kaspir
Post by kaspir »
Scanialady wrote: Jan 19th, '17, 14:01 thank you for your answer, kaspir :)
Apologies, thought I was being helpful.. and I'm just super angry.. might not want to take advice from me on these bbcodes, and I certainly will not give any anymore.
kaspir
Post by kaspir »
I do not see any of the MODX_CMD in the bbcodes DB table. Thought's that what you may have meant.
{L_MODX_CMD} Why is it not showing language variables again? I mean, your is working, I'm using the same ext.. is this in code somewhere? seriously?
I would reinstall the ext MODx commands you dont need to make any bbcodes.
If you updated from 3.1.10 to 3.2 you may have lost the table for it.
kaspir
Post by kaspir »
martin wrote: Jan 19th, '17, 15:32 I would reinstall the ext MODx commands you dont need to make any bbcodes.
I did, but installed ext after the update. What is the name of the table?
c and s were the only two customs that came with 3.2 right?
Let it be noted, I've done this also: https://www.phpbb.com/customise/db/exte ... x/faq/2011
I have a backup ready.
Hmm its working on a fresh phpbb 3.2 install (i dont have the user name ext installed but used the modx ext from my site and that does have user name edit in it thats why you see it)
kaspir
Post by kaspir »
martin wrote: Jan 19th, '17, 16:12 hmm its working on a fresh phpbb 3.2 install (i dont have the user name ext installed but used the modx ext from my site and that does have user name edit in it thats why you see it)
Yea mine didn't show mate. I removed all custom bbcodes that didn't work, left with the list below that all work.
This is what I got now after editing the ext files, but Badge Extensions has also been active, so I'll need to add that next.
Also, username ext.. gone.
EDIT// And.. DONE!
:thumbup: again, thx for ext martin
I'll go away now. :beers:
