Support Request SupportHow to unistall mchat
Support Section
Neves
Post by Neves »
Your phpBB Version: Latest
Extensions installed: No
Your knowledge: Beginner
Boardlink: http://nevesprojects.com/
Tried to deactivate mchat
tried to delete mchat files through ftp
Hi I tried to deactive mchat cause I didn't want it on top of forums and now I'm locked out of my administration page.
All i'm getting is a blank white page.
How can I completely remove mchat so I can get into my admin section ?
Re: How to unistall mchat
If you deleted the mchat folder just ftp them back.
You need to disable mchat in ACP like an normal extension.
In the cache folder delete the production folder so you can access ACP again.
You can set mchat below forum btw in settings.
