Question Questions ⇒ PDF files uploaden in file upload is denied
ArrayHensyr Wolf
- Status: Offline
- User theme: Dark
Good evening, when i try to upload a pdf file in the file upload extension, it wil not work.
How can i upload pdf files with this extension?
ArrayGizmo Online
- Donator
- Status: Online
- User theme: Dark
Re: PDF files uploaden in file upload is denied
Mate not sure if right but you might need to add pdf to this in acp, I never tried it so not sure it will work
Allowed extensions:
Allowed extensions to include, separated by a comma (Example: gif,jpeg,jpg,png)
Allowed extensions:
ArrayHensyr Wolf
- Status: Offline
- User theme: Dark
Thanks for your reply but i don't know how
ArrayGizmo Online
- Donator
- Status: Online
- User theme: Dark
ACP > extensions > Image Upload > Configuration, then 3rd down from top you will see allowed extensions you add pdf (Example: gif,jpeg,jpg,png,pdf) in that line then submit, remember I have never tried to add this into mine
ArrayHensyr Wolf
- Status: Offline
- User theme: Dark
Thank you very much, i will try it out
ArrayHensyr Wolf
- Status: Offline
- User theme: Dark
ArrayGizmo Online
- Donator
- Status: Online
- User theme: Dark
That is different to the one I thought you were talking about I think file upload is only for these Allowed extensions 'zip', 'rar'
ArrayHensyr Wolf
- Status: Offline
- User theme: Dark
With this extension two years back i was able to upload pdf files
I know there must be a setting to make this possible but now i forget how
ArrayGizmo Online
- Donator
- Status: Online
- User theme: Dark
ArrayHensyr Wolf
- Status: Offline
- User theme: Dark
I have looked in the section posts and pdf file are allowed but not for the file upload extension
ArrayGizmo Online
- Donator
- Status: Online
- User theme: Dark
Ah ok maybe dm or martin might be able to sort it keep checking site for any update they might have to help you
ArrayHensyr Wolf
- Status: Offline
- User theme: Dark
Thank you so much for helping me
i will wait for an answer from them
ArraySniper_E
- Status: Offline
- User theme: Dark
I added pdf like Gismo posted.Gizmo wrote: Jan 29th, '25, 01:21 ACP > extensions > Image Upload > Configuration, then 3rd down from top you will see allowed extensions you add pdf (Example: gif,jpeg,jpg,png,pdf) in that line then submit, remember I have never tried to add this into mine
Then I changed the pdf from Documents to Images in ACP Posting tab.
Then cleared my cache and uploaded my pdf file with img-upload and submitted.
Then I chose the [url link for the file and posted it... https://www.sniper-e.net/viewtopic.php?p=278#p278
ArrayHensyr Wolf
- Status: Offline
- User theme: Dark
Do I also need to install the image upload extension?
ArraySniper_E
- Status: Offline
- User theme: Dark
Not if you can find the files for file-upload to add the pdf to expectable ext.
I looked at all the file but must have over looked it.
Then you could change the pdf from Documents to Archives. Or maybe it will work as Documents.
I looked in file-upload again and still did not see it. But it has to be there.
