Off-TopicHow to fixed extension BGTOP
All the various Off-Topic crap here ;)
HarveyWNvm LLC.
Post by HarveyWNvm LLC. »
I have done everything necessary
Post
https://www.phpbb.com/community/viewtopic.php?t=2649862
Version
https://appunlockstoryplay.top/versions ... rsion.json
Github
https://github.com/HarveyWNvm/bgtop
Chek Version available
Error Access
code:
	"name": "hrvy/bgtop",
	"type": "phpbb-extension",
	"description": "Made by appunlockstoryplay.top",
	"homepage": "https://appunlockstoryplay.top/",
	"version": "1.1.2",
	"time": "2024-01-13",
    "keywords": [
        "phpbb",
        "extension",
        "bgtop"
	"license": "GPL-2.0",
	"authors": [
			"name": "HarveyWNvm",
			"email": "harveynomvervevo@gmail.com",
			"role": "Editor Extension"
	"require": {
		"php": ">=8.2.14"
	"extra": {
		"display-name": "BGTOP by HarveyWNvm",
		"soft-require": {
			"phpbb/phpbb": ">=3.3.11,<4.0.x*@dev"
		"version-check": {
			"host": "www.appunlockstoryplay.top",
			"directory": "/versions",
			"filename": "bgtop_version.json",
			"ssl": true
Overall_Header_before
<a class="forkit" data-text="Top Secret" data-text-detached="Drag down >" target="_blank" href="https://bgtop.net/vote/1301663796"><img style="position: absolute; top: 0; right: 0; border: 0;" src="https://i.imgur.com/0x9vF7O.png" alt="Гласувай за нас в BGTOP"></a>
nFL-Cs.InFo Clock to Banner
HarveyWNvm LLC.
Re: How to fixed extension BGTOP
Do want to helpme?
Banned
Banned
return version_compare($config['version'], '3.3.11', '>=');
What is your phpBB version?
HarveyWNvm LLC.
Website off shuting why?
Banned
Banned
As we don't know what you're talking about it's difficult to answer you.
The way I read it, he is making his own ext and needs help ????? Maybe...
HarveyWNvm LLC.
clight77 wrote: Jan 23rd, '24, 03:26 The way I read it, he is making his own ext and needs help ????? Maybe...
Yes, but I need to fix it so that it doesn't stop the site at al
Sorry I do not know how to make or fix an ext. :(
SpIdErPiGgY
Post by SpIdErPiGgY »
In overall_header_head_append.html, change ut to {% INCLUDECSS 'bgtop.css' %}
🌐 phpBB Extensions in Dutch
💚 Support this project on Ko-fi
Or maybe change to {% INCLUDECSS '@hrvy_bgtop/bgtop.css' %}
HarveyWNvm LLC.
I think this is the mistake I am currently using
<!-- INCLUDECSS @appunlockstoryplay_bgtop/bgtop.css -->
Up....
fixed on problem
SpIdErPiGgY
    Android Firefox
And what does this ext do? I can't see... 🫣🤣
HarveyWNvm LLC.
This extension is added to the top vote You can see it [3.3][RC] BGTOP 3.3.x
HarveyWNvm LLC.
So everything is correct, but something from when I get an error. Something doesn't match under my name
Note: composer.json
	"version": "1.1.2",
    "keywords": [
        "phpbb",
        "extension",
        "bgtop"
	"authors": [
	"require": {
		"php": ">=8.2.14"
	"extra": {
		"soft-require": {
		"version-check": {
			"ssl": true
SpIdErPiGgY
    Android Firefox
Yeah so...? Read the error message 🫣
