Support Request Support ⇒ Donation extension problems on phpBB 3.3.10
- Donator
- Magic user status: Offline
Your phpBB Version: 3.3.10
Your knowledge: Advanced Knowledge
Boardlink: https://www.maaca.org/
PHP Version: 8.1
Upgraded my forum from phpBB 3.3.0 to phpBB 3.3.10.
Upgraded from PHP 7.4 to PHP 8.1.
Nothing yet
Hi, got the Donation Extension from here in 2020 and it has been working flawlessly since then.
I am running version 1.3.1.
Since I upgraded to phpBB 3.3.10 earlier this week the extension is not working anymore. The donations are not added to the list and not shown on the site.
I was wondering if version 1.4.0 would fix that ? Would like to try it if it's the case, please let me know.
Here's the error I am getting, it is related to MySQL:
[18-May-2023 14:00:02 America/Los_Angeles] PHP Fatal error: Uncaught TypeError: in_array(): Argument #2 ($haystack) must be of type array, null given in /home/azatotht/maaca.org/ext/dmzx/donation/controller/ipn.php:86
Stack trace:
#0 /home/azatotht/maaca.org/ext/dmzx/donation/controller/ipn.php(86): in_array(NULL, NULL)
#1 /home/azatotht/maaca.org/vendor/symfony/http-kernel/HttpKernel.php(151): dmzx\donation\controller\ipn->handle_ipn()
#2 /home/azatotht/maaca.org/vendor/symfony/http-kernel/HttpKernel.php(68): Symfony\Component\HttpKernel\HttpKernel->handleRaw(Object(phpbb\symfony_request), 1)
#3 /home/azatotht/maaca.org/app.php(35): Symfony\Component\HttpKernel\HttpKernel->handle(Object(phpbb\symfony_request))
#4 {main}
thrown in /home/azatotht/maaca.org/ext/dmzx/donation/controller/ipn.php on line 86
PHP Version: 8.1
Nothing yet
Stack trace:
#4 {main}
Re: Donation extension problems on phpBB 3.3.10
I see 1.3.1, see below
- Updated code for add config.
- Redo paypal to use curl.
- Code update for functions_donation.php
- Code update for php 8.x
- Donator
Thank you, will get version 1.4.0
What is the best recommended way to upgrade without losing the actual datas that I have ?
Disable old extension, replace folder with the new one, re-enable ?
Or should I do it any other ways ?
Yes in that order is ok, but make backup also.
You need to install also other extensions you will see in original post of donation extenion.
Backup always your database
- Donator
Allright, will give it a try and let you know if I need more help.
Thanks a lot.
Thanks a lot.
- Donator
Installed the new version and everything seems to be working again.
Installed auto-groups extension from phpBB and also installed the recommended add config extension from here.
I added a donation manually using the add donor option in the acp but the expiry date is wrong.
User has been added to VIP25 group properly but the expiry date does not show up:
Here's my group setting (configured since version 1.3.1):
Should I add anything to the auto-groups section of the forum to make it work ?
Thanks for your help.
- Donator
Only in VIP25 and registered users.
- Donator
Changed the option to on, still see wrong expiry date
- Donator
I tried that.
Removed user from VIP25 then added another donation manually.
He got added to VIP25, total donation amount of this user is good (25$ more), but the expiry date is still wrong.
Donation expiry in -19496 days
- Donator
Expiry date is wrong for all of them:
