ToolsMODX Creator downloads
phpbb3 tools
    unknown unknown
Description
The MODX Creator is a tool to create and edit MODX install files.
You can even import a MODX file or a MOD text file to the Creator and get a valid MODX install file.
The generated MODX file can be installed automatically with AutoMOD.
Getting started
To install the off-line version, simply extract the MODX Creator off-line package somewhere on your computer where you can access it using a browser. Then just point your browser to that directory and you are in business.
The phpBB version can easily be installed with AutoMOD or by following the instructions in the attached install file.
modx_creator_phpbb-1.2.6-PL2.zip
