Support Request SupportTrying to make attribut as here
Support Section
Magic user status: Online
Your phpBB Version: 3.3.9
Your knowledge: Beginner
Boardlink: https://bgrock.eu/testboard2/
Just follow the steps as in topic here
Prefix CSS for Quick Title Edition 2.0.0
but see white page
clear chache and follow the steps
i test it on my test forum 1st
i want to use this ext beacouse of permission to edit attribut on other users
/ext/ernadoo/qte/styles/prosilver/theme
 * @package Quick Title Edition Extension
 * @copyright (c) 2015 ABDev
 * @copyright (c) 2015 PastisD
 * @copyright (c) 2015 Geolim4 <http://geolim4.com>
 * @copyright (c) 2015 Zoddo <zoddo.ino@gmail.com>
/* selector */
fieldset.attribute {
    text-align: right;
    margin-top: 15px;
    height: 2.5em;
/* attributes */
.qte_solved { color: #006600; }
.qte_cancelled { color: #cc0000; }
.qte_solved, .qte_cancelled { font-weight:bold; }
/* imageset */
.imageset.qte_solved {
    background-image: url("./images/icon_topic_solved.gif");
    padding-left: 16px;
    padding-top: 16px;
.imageset.qte_cancelled {
    background-image: url("./images/icon_topic_cancel.gif");
    padding-left: 16px;
    padding-top: 16px;
qte_topicsolved {
	color: #FFF;
	background-color: #88DB43;
	-webkit-border-radius: 4px;
	-o-border-radius: 4px;
	-moz-border-radius: 4px;
	border-radius: 4px;
	padding: 2.1px;
	overflow: hidden;
	font-weight: bold;
/ext/ernadoo/qte/language/en
<?php
// ignore
if (!defined('IN_PHPBB'))
	exit;
// init lang ary, if it doesn't !
if (empty($lang) || !is_array($lang))
	$lang = array();
	'QTE_CAN_USE_ATTR'	=> 'Can use %s attribute',
	// select
	'QTE_ATTRIBUTES' => 'Topic attributes',
	'QTE_ATTRIBUTE' => 'Topic attribute',
	'QTE_ATTRIBUTE_ADD' => 'Select a topic attribute',
	'QTE_ATTRIBUTE_REMOVE' => 'Remove the topic attribute',
	'QTE_ATTRIBUTE_DESIRED' => 'Select desired attribute',
	'QTE_ATTRIBUTE_KEEP' => 'Keep the actual attribute',
	// notifications
	'QTE_ATTRIBUTE_ADDED' => 'An attribute has been applied to the topic title',
	'QTE_ATTRIBUTE_UPDATED' => 'The attribute of that topic has been updated',
	'QTE_ATTRIBUTE_REMOVED' => 'The topic attribute has been removed',
	'QTE_TOPIC_ATTRIBUTE_ADDED' => 'An attribute has been applied to the selected topic',
	'QTE_TOPICS_ATTRIBUTE_ADDED' => 'An attribute has been applied to the selected topics',
	'QTE_TOPIC_ATTRIBUTE_UPDATED' => 'The attribute of the selected topic has been updated',
	'QTE_TOPICS_ATTRIBUTE_UPDATED' => 'The attribute of the selected topics has been updated',
	'QTE_TOPIC_ATTRIBUTE_REMOVED' => 'The attribute of the selected topic has been removed',
	'QTE_TOPICS_ATTRIBUTE_REMOVED' => 'The attribute of the selected topics has been removed',
	// search
	'QTE_ATTRIBUTE_SELECT' => 'Select a topic attribute',
	'QTE_ATTRIBUTE_SEARCH' => 'Search for attributes',
	'QTE_ATTRIBUTE_SEARCH_EXPLAIN' => 'Select the attribute you wish to search',
	// sort
	'QTE_SORT' => 'As attribute',
	'QTE_ALL' => 'All',
	// mistake messages
	'QTE_ATTRIBUTE_UNSELECTED' => 'You must select an attribute!',
	// placeholders
	'QTE_KEY_USERNAME' => '¦user¦',
	'QTE_KEY_DATE' => '¦date¦',
// topic attributes as keys
	'QTE_SOLVED' => '[Solved by %mod% :: %date%]',
	'QTE_CANCELLED' => 'Cancelled',
'qte_topicsolved' => 'Solved',
[/i]
Re: Trying to make attribut as here
Post the 2 files here so I can add it correctly for you.
dmzx wrote: Jan 17th, '23, 14:36 Post the 2 files here so I can add it correctly for you.
here is it
this is file from eng language
Click here do download en file
here is FILE from theme folder
Downloads.zip
Above the files, read the part for ACP in the main topic to add it there.
dmzx wrote: Jan 18th, '23, 08:42 Downloads.zip
yes, i did it as you told men for ACP part, but i don't have group permission as in the main topic
also can't set other user topic attribute
PM me test admin account
dmzx wrote: Jan 18th, '23, 12:02 PM me test admin account
I did check your board, did you install this ext Prefix CSS for Quick Title Edition 2.0.0 ?
dmzx wrote: Jan 18th, '23, 13:08
yes, i get it from here
You have to install this extension (>Quick Title Edition 2.0.0<)
from the main topic, i just change the name so ext to be installed
dmzx wrote: Jan 18th, '23, 14:39 use this one Prefix CSS for Quick Title Edition 2.0.0
You mean of author abdev ?
ivailo95 wrote: Jan 18th, '23, 14:41
yes installed also here
Can i apply the same files you gave me or?
btw
phpBB encountered an error building the container due to an installed extension. For this reason, all extensions have been temporarily disabled. Please try purging your forum cache. All extensions will automatically be re-enabled once the container error is resolved. If this error continues, please visit phpBB.com for support.
Exception: The file "/home/bgrockeu/public_html/testboard2/ext/abdev/qte/config/services.yml" does not contain valid YAML: The reserved indicator "@" cannot start a plain scalar; you need to quote the scalar at line 5 (near "- @request").
#0 /home/bgrockeu/public_html/testboard2/vendor/symfony/dependency-injection/Loader/YamlFileLoader.php(117): Symfony\Component\DependencyInjection\Loader\YamlFileLoader->loadFile('/home/bgrockeu/...')
#1 /home/bgrockeu/public_html/testboard2/phpbb/extension/di/extension_base.php(99): Symfony\Component\DependencyInjection\Loader\YamlFileLoader->load('services.yml')
#2 /home/bgrockeu/public_html/testboard2/phpbb/extension/di/extension_base.php(63): phpbb\extension\di\extension_base->load_services(Object(Symfony\Component\DependencyInjection\Compiler\MergeExtensionConfigurationContainerBuilder))
#3 /home/bgrockeu/public_html/testboard2/vendor/symfony/dependency-injection/Compiler/MergeExtensionConfigurationPass.php(71): phpbb\extension\di\extension_base->load(Array, Object(Symfony\Component\DependencyInjection\Compiler\MergeExtensionConfigurationContainerBuilder))
#4 /home/bgrockeu/public_html/testboard2/vendor/symfony/http-kernel/DependencyInjection/MergeExtensionConfigurationPass.php(39): Symfony\Component\DependencyInjection\Compiler\MergeExtensionConfigurationPass->process(Object(Symfony\Component\DependencyInjection\ContainerBuilder))
#5 /home/bgrockeu/public_html/testboard2/vendor/symfony/dependency-injection/Compiler/Compiler.php(140): Symfony\Component\HttpKernel\DependencyInjection\MergeExtensionConfigurationPass->process(Object(Symfony\Component\DependencyInjection\ContainerBuilder))
#6 /home/bgrockeu/public_html/testboard2/vendor/symfony/dependency-injection/ContainerBuilder.php(789): Symfony\Component\DependencyInjection\Compiler\Compiler->compile(Object(Symfony\Component\DependencyInjection\ContainerBuilder))
#7 /home/bgrockeu/public_html/testboard2/phpbb/di/container_builder.php(223): Symfony\Component\DependencyInjection\ContainerBuilder->compile()
#8 /home/bgrockeu/public_html/testboard2/common.php(117): phpbb\di\container_builder->get_container()
#9 /home/bgrockeu/public_html/testboard2/adm/index.php(23): require('/home/bgrockeu/...')
#10 {main}
It's work fine with Ernadoo ext
Ivallo95, replace your services.yml file by this :
services:
    abdev.qte:
        class: abdev\qte\qte
        arguments:
            - '@request'
            - '@cache.driver'
            - '@config'
            - '@dbal.conn'
            - '@template'
            - '@user'
            - '@log'
            - '%core.root_path%'
            - '%core.php_ext%'
            - '%core.table_prefix%'
    abdev.qte.main_listener:
        class: abdev\qte\event\main_listener
        arguments:
            - '@request'
            - '@dbal.conn'
            - '@template'
            - '@user'
            - '@log'
            - '@abdev.qte'
        tags:
            - { name: event.listener }
    abdev.qte.acp_listener:
        class: abdev\qte\event\acp_listener
        arguments:
            - '@request'
            - '@cache.driver'
            - '@dbal.conn'
            - '@user'
            - '@abdev.qte'
        tags:
phpBB: 3.3.10 | PHP: 8.2
Thank you ssl and dmzx i appriciated you help ! :thumbup: :buigen:
