Download Modifications for phpBB3Screen resolution in viewtopic
Downloads for phpBB3
See last post.
olalavui
Re: Screen resolution in viewtopic
Post by olalavui »
Can you update for phpbb 3.2.x :)
Come back phpBB with phpBBVietnam :tumbsyes:
olalavui wrote: Jun 27th, '17, 21:50 Can you update for phpbb 3.2.x :)
I am using it on 3.2 all seems fine for me.
olalavui
Post by olalavui »
clight77 wrote: Jun 27th, '17, 21:52I am using it on 3.2 all seems fine for me.
This mod for phpBB 3.0.x, current i use phpBB 3.2.x & i see dmzx use this as extension :tumbsyes:
olalavui wrote: Jun 27th, '17, 22:02
There are no mods here on this site, either 3.1 or 3.2 and for the most part 3.1 ext work on 3.2
This is for 3.1 or 3.2
olalavui
Post by olalavui »
I try re-download but in screen_resolution_in_viewtopic_v1 folder only have 3 file
  • install_mod.xml
  • license.txt
  • modx.prosilver.en.xsl
I had read install_mod.xml but currently i not see same on this forum :coffee:
alaturka
Post by alaturka »
Thankyou :beers:
Topic locked as this is for 3.0 and that is no longer supported you can find a port of it here Screen resolution in viewtopic
