Support Request Supportbanned after sending mails with newsletter extension
Support Section
medic
Post by medic »
Your phpBB Version:3.3.4
Your knowledge: Beginner
Boardlink: https://amis-med.com/forum
PHP Version: 7.4.20
upgrade to 1.0.3 newsletter
i contacted support they unban my domain because i didnt respect the limit of 200 emails/h fixed by ovh
i back to version 1.0.2 and send 75 mails/h by shoosing th members it take long time do it i have more than 1200
Your phpBB Version:
Extensions installed: No
PHP Version: 7.4.20
hi bro
sorry my english isnt that good
your extension is the best one to send html mails
im asking is there a way to add option like the standard mass mass mails of phpbb and make it play with rules of the chron and the limitation in admin pannel to avoid over pass the limit of 200 emails/h
thank you
medic
Re: banned after sending mails with newsletter extension
Post by medic »
Up plz
