Support Request SupportHTML email
Support Section
Pingui
HTML email
Post by Pingui »
Your phpBB Version: 3.3.4
Boardlink: https://www.winuaespanol.com
PHP Version: 7.4.19
Before I had the problem I had phpBB version 3.3.3 installed.
Nothing
The problem that has happened to me is that when I upgraded to phpBB 3.3.4, users can not register to the forum via email because when they click on "Send" they get a blank web page where you can read HTTP ERROR 500.
Instead, if I disable this extension the user registration via email works.
Why could this be?
Is there a new version for phpBB 3.3.4?
If so, where is it?
Thanks for your help.
Be yourself, except if you're stupid, then it is better that you be another one.
I Amiga
- www.WinUAEspanol.com
I know, my english is very bad, sorry...
Re: HTML email
Try to disable the html ext. and delete data also, then reinstall the html ext.
I dont know if this is really the problem, otherwise PM me the url and admin account
Pingui
Re: HTML email
Post by Pingui »
Hi dmzx...
dmzx wrote: Jul 1st, '21, 06:19 Try to disable the html ext. and delete data also, then reinstall the html ext.
Yes, that's it!
I did what you said and the extension is working again.
As always, thanks for your help.
Re: HTML email
Pingui wrote: Jul 1st, '21, 12:48 Hi dmzx...
Yes, that's it!
