Your phpBB Version: 3.3
Your knowledge: Beginner
Boardlink: -
Boardlink: -
Extensions installed: No
Your knowledge: Advanced Knowledge
Boardlink: -
Hello dmzx, just wanted to let you know that you've got a bug here on the website.
Tried to log into an old account, password was wrong, asked to reset, got the email, clicked the link but instead of being taken to the password reset page I was just redirected back to your login/register splash, making password resets impossible. Posting from a new account in the meantime.
Support Request Support ⇒ Resending password doesn't work here on this website
- New user
- Magic user status: Offline
Re: Resending password doesn't work here on this website
Ok will check it, thanks for reporting.
- Donator
I had the same issue because I was using login required by Kasimi extension and needed to add to the allowed list... Not sure if that is your issue or not...
- user/forgot_password
- app.php/user/forgot_password
- user/reset_password
- app.php/user/reset_password
Issue solved here now
- Donator
