Question Questions ⇒ ultieme points problem?
Arrayfaroud
- Status: Offline
- User theme: Dark
The extension ultimate points has a bug?
when opening a forum or topic
you will see some bug rules at the top of the forum overview
this one?
[phpBB Debug] PHP Notice: in file [ROOT] /ext/dmzx/ultimatepoints/event/listener.php on line 438: Trying to access array offset on value of type bool
with some 5 bug rules?
work with phpbb 3.3.2
Greetings
faroud
this one?
Greetings
faroud
Arrayfaroud
- Status: Offline
- User theme: Dark
Re: ultieme points problem?
I keep seeing the bug rules?
too bad I had to remove it
I like to put it back
if it is fixed?
for phpbb 3.3.0 or later
thanks
if it is fixed?
thanks
Arraydmzx
- Status: Offline
- User theme: Dark
Will install and check soon.faroud wrote: Apr 1st, '21, 16:02 I keep seeing the bug rules?
if it is fixed?
thanks![]()
Arrayfaroud
- Status: Offline
- User theme: Dark
Arraymasterbiz_21
- Status: Offline
- User theme: Dark
Ciao i get the same errorfaroud wrote: Dec 30th, '20, 11:25 the extension ultimate points has a bug?
this one?
Greetings
faroud
I wanted to report this error happens if you update php 7.4, with 7.3 it is in order
Arrayfaroud
- Status: Offline
- User theme: Dark
I will wait
because soon a new phpbb version
then it is php 8
ultimate points will have to be updated anyway?
then it is php 8
Arraydmzx
- Status: Offline
- User theme: Dark
Arraymasterbiz_21
- Status: Offline
- User theme: Dark
You are great, thank you
Arrayfaroud
- Status: Offline
- User theme: Dark
It works perfectly now
thank you
regards
thank you
regards
ArrayBrunchs
- Status: Offline
- User theme: Dark
Fatal error: Cannot declare class p_master, because the name is already in use in /home/clients/04bba139eb5e41020ef875068f42a5f4/web/includes/functions_module.php on line 25
Explained myself poorly when I click on the points I have this error
Arrayfaroud
- Status: Offline
- User theme: Dark
I have no problem with this extension
you changed the name before the upload
of the folder?
of the folder?
ArrayBrunchs
- Status: Offline
- User theme: Dark
