Your phpBB Version: 3.3.2
Your knowledge: Beginner
PHP Version: 7.3.24
just installed it
goes to download from main site then
General Error
SQL ERROR [ mysqli ]
also downlading files do not work cant even download it
tryed looking at the settings but no luck clean install
Support Request Support ⇒ looking for help with
- Magic user status: Offline
Re: looking for help with
This is in relation with the download system
i am using bitnami stacks with this install
QL ERROR [ mysqli ]
Expression #17 of SELECT list is not in GROUP BY clause and contains nonaggregated column 'bitnami_phpbb . bd . download_id' which is not functionally dependent on columns in GROUP BY clause; this is incompatible with sql_mode=only_full_group_by [1055]
SQL
SELECT bc.*, bd.*, COUNT(bd.download_id) AS number_downloads, MAX(bd.last_changed_time) AS last_download FROM phpbb_dm_eds_cat bc LEFT JOIN phpbb_dm_eds_cat bc2 ON ( bc2.left_id < bc.right_id AND bc2.left_id > bc.left_id AND bc2.cat_id = 0 ) LEFT JOIN phpbb_dm_eds bd ON ( bd.download_cat_id = bc.cat_id OR bd.download_cat_id = bc2.cat_id ) WHERE bc.parent_id = 0 GROUP BY bc.cat_id ORDER BY bc.left_id ASC LIMIT 25
BACKTRACE
FILE: (not given by php)
LINE: (not given by php)
CALL: msg_handler()
LINE: 1023
CALL: trigger_error()
LINE: 195
FILE: [ROOT]/phpbb/db/driver/mysql_base.php
LINE: 45
LINE: 296
CALL: phpbb\db\driver\mysql_base->_sql_query_limit()
LINE: 337
CALL: phpbb\db\driver\driver->sql_query_limit()
FILE: [ROOT]/ext/dmzx/downloadsystem/core/functions.php
LINE: 388
CALL: phpbb\db\driver\factory->sql_query_limit()
FILE: [ROOT]/ext/dmzx/downloadsystem/controller/download.php
LINE: 72
CALL: dmzx\downloadsystem\core\functions->generate_cat_list()
FILE: [ROOT]/vendor/symfony/http-kernel/HttpKernel.php
LINE: 151
CALL: dmzx\downloadsystem\controller\download->handle_downloadsystem()
LINE: 68
CALL: Symfony\Component\HttpKernel\HttpKernel->handleRaw()
FILE: [ROOT]/app.php
LINE: 35
CALL: Symfony\Component\HttpKernel\HttpKernel->handle()
SQL
BACKTRACE
CALL: msg_handler()
LINE: 1023
LINE: 195
LINE: 45
LINE: 296
LINE: 337
LINE: 388
LINE: 72
LINE: 151
LINE: 68
LINE: 35
