Support Request SupportWallet Index
Support Section
sqpp
    Windows 10 Edge
Wallet Index
Post by sqpp »
Your phpBB Version: 3.3.0
Your knowledge: Beginner
PHP Version: 7.2
Just installed the extension, so nothing.
I have removed the extension completely and installed the latest v.1.0.3 version.
PHP Version: 7.2
PHP Version: 7.2
Hey,
So I don't know what else could I do or to know what is wrong, but whenever I change the settings in the Wallet Extension and press Submit, it logs me out of ACP. How could I debug the problem exactly?
Cookie settings seems fine as well.
Regards,
Marcell
Re: Wallet Index
Sound like a cookie issue to make sure your cookie is like this in the acp .mysite.com note the leading dot.
sqpp
    Windows 10 Edge
Re: Wallet Index
Post by sqpp »
Yeah, of course, that was the first thing I checked, but no, it starts with dot following the domain name, which is the correct format.
