3.2 & 3.3 Extensions Database 3.2 / 3.3Add Config
Add Config
Extension Name: Add Config
Author: dmzx & martin
Add Config is a helper extension for some extension, no settings can be done and you will get an message when enabling extensions if this extension is required.
Note: Read below first before updating
To install the new version First copy the ext.php from the new 1.0.1 files to the directory ext\dmzx\addconfig.
After that disable and install new files and update to version 1.0.1.
- Redo code.
Code update.
None
  2. Unzip the downloaded release, and change the name of the folder to `addconfig`.
  4. Copy the `addconfig` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/addconfig/composer.json
  6. Look for `Add Config` under the Disabled Extensions list, and click its `Enable` link.
Re: Add Config
hybridmind
Re: Add Config
Post by hybridmind »
/home/webocean/public_html/community/vendor/symfony/event-dispatcher/EventDispatcher.php(214): dmzx\addconfig\event\main_listener->page_header(Object(phpbb\event\data), 'core.page_heade...', Object(phpbb\event\dispatcher))
#1 /home/webocean/public_html/community/vendor/symfony/event-dispatcher/EventDispatcher.php(44): Symfony\Component\EventDispatcher\EventDispatcher->doDispatch(Array, 'core.page_heade...', Object(phpbb\event\data))
#2 /home/webocean/public_html/community/phpbb/event/dispatcher.php(62): Symfony\Component\EventDispatcher\EventDispatcher->dispatch('core.page_heade...', Object(phpbb\event\data))
#3 /home/webocean/public_html/community/phpbb/event/dispatcher.php(46): phpbb\event\dispatcher->dispatch('core.page_heade...', Object(phpbb\event\data))
#4 /ho in /home/webocean/public_html/community/ext/dmzx/addconfig/event/main_listener.php on line 94
This error, constantly coming out, is there a solution?
Maclobster
Re: Add Config
Post by Maclobster »
hybridmind wrote: 07 Sep 2020, 11:18
Had the same error, your provider maybe strato.nl?
regards
“A man searching for the Lost Paradise, can seem a fool to those who never sought the other world.”
-JM
Re: Add Config
What phpbb version and php you using ?
Maclobster
Re: Add Config
7.3.21
3.3.1
have a option at provider to set on 7.4
Re: Add Config
