Author: HiFiKabin
Extension description: Extension Name: April Falls
Author: HiFiKabin
Extension Description: Makes the index page of your board look broken and out of alignment.
All of the links will work as they should.
Extension Version: 3.2.0
Supported Styles:
- prosilver
- Download the latest release and unzip it.
- Upload the folder hifikabin to root/ext/ and enable it in the ACP
The Contact Us link at the bottom of this Forum or This Topic
Extension version: 3.2.0
Tested on phpBB version: 3.2.9
Download file: aprilfalls_3_2_0.zip
File size: 6.96 KiB
Source: [url]https://www.phpbb.com/community/viewtopic.php?t=2556526&p=15528021#p15528021
