{% IF S_USER_LOGGED_IN %} If a user is logged in
{% if S_USER_LOGGED_IN %}your content here (for users logged in){% ELSE %}your content here (for viewing as a guest){% endif %}
{% if S_REGISTERED_USER %} If user is logged in and not a bot
{% if S_AUTOLOGIN_ENABLED %} If auto login is allowed
{% if S_BOARD_DISABLED %} If board is disabled
{% if S_IS_BOT %} If a bot
{% if S_USER_PM_POPUP %} If pop up pm is on
{% if S_DISPLAY_SEARCH %} If displays search
{% if S_DISPLAY_PM %} If display a PM
{% if S_DISPLAY_MEMBERLIST %} If display memberlist.php
{% if U_MCP %} If Moderator
{% if U_ACP %} If Administrator
{% if S_IS_LINK %} If its a link
{% if S_UNREAD_FORUM %} If forum is unread
{% if S_READ_FORUM %} If forum is read
{% if S_LOCKED_FORUM %} If forum is locked
{% if S_LIST_SUBFORUMS %} If there is a list of subforums
{% if S_SUBFORUMS %} If a subforum
{% if S_IS_CAT %} If a category
{% if S_IS_POST %} If a post
{% if FORUM_ID %} Displays the code between the switches if the user is viewing a particular forum.
{% if SCRIPT_NAME == "index" %}some content{% endif %} (Others you can use, viewtopic,viewforum,memberlst,faq etc)
{% if S_USERNAME eq "dmzx" %}Some content here{% endif %}
Let's say you wanted something to show in an html file for registered users only, then you could use the following
{% if S_REGISTERED_USER %}Hello, welcome to blahblah.com{% endif %}
or
{% if FORUM_ID eq 2 %}Welcome to Forum Number 2{% endif %}
You can also combine the if's
{% if FORUM_ID eq 2 and S_REGISTERED_USER %}Welcome to Forum ID #2 and you are a registered user{% endif %}
or ( || )
and ( && )
eq ( == )
You can use either the language ones (or, and, eq) or the other ones ( ||, &&, ==).
Remember each time you have a {% if something %} statement you must also have an ending {% endif %} statement, else you will get errors when the templating engine does it's stuff.
These work with cssmagic 3.0.9 no core edit needed to make them work or marti group template ext not needed either.
