Support Request SupportSmilies Categories
Support Section
Midway
Smilies Categories
Post by Midway »
Your phpBB Version: 3.3.0
Extensions installed: No
I have an extension Smilies Categories and I would like to know if it is possible to adapt it with mchat?
Status: Online
Re: Smilies Categories
Yes
Midway
Post by Midway »
And how ?
Status: Online
I don't know. -- NEED MORE INFORMATION --
First we would need to know what smilies category extension you are using. :whistl:
Midway
Post by Midway »
Yes no problem I send you the extension by PM
Status: Online
Got it thanks. Installed. I get an error when I click View more smilies so I will have to look at it later.
SQL ERROR [ mysqli ]
You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near 'GROUP BY emotion ORDER BY smiley_order ASC LIMIT 50' at line 1 [1064]
SQL
SELECT s.*, c.* FROM (phpbb_smilies s) LEFT JOIN phpbb_smilies_category c ON (c.cat_id = s.category AND c.cat_lang = 'en') WHERE category = GROUP BY emotion ORDER BY smiley_order ASC LIMIT 50
