Support Request SupportChange backgroundcolor on index from new reply on post in forum
Support Section
TWEagle
Post by TWEagle »
Your phpBB Version:
Boardlink: https://offorum.eu
I have tried a lot but don't find what I need to add to my colours.css file
yes
Hey all
I want to change the background color of the forum when there is a new reply in that forum.
I had it earlier but don't remember how to fix it
Re: Change backgroundcolor on index from new reply on post in forum
Forumlist_body.html (line 32)
		<li class="row"<!-- IF forumrow.S_UNREAD_FORUM --> style="background-color: #aaffff"<!-- ENDIF -->>
Or go all out and use this in the forumlist_body
		<li class="row<!-- IF forumrow.S_UNREAD_FORUM --> row2<!-- ENDIF -->">
And add this in the coulours.css
.row2 {
	background-color: #aaffff;
TWEagle
Post by TWEagle »
Sniper_E wrote: Mar 29th, '20, 17:43 forumlist_body.html (line 32)
.row2 {
Is the second part correct??
Yes it is correct. But you can name that class whatever you want... like this below, just add that new class in the .css
		<li class="row<!-- IF forumrow.S_UNREAD_FORUM --> newpost<!-- ENDIF -->">
.newpost {
Does that help you understand it? Or like that first edit... use the style="background-color: #aaffff" in the template and be done.
TWEagle
Post by TWEagle »
I have changed it like you said but I don't see it
Did I do something wrong
I feel myself dumb
TWEagle
Post by TWEagle »
TWEagle wrote: Mar 31st, '20, 07:38 I have changed it like you said but I don't see it
I feel myself dumb
Have I done something wrong myself then?
Your code looks right
	<!-- IF not forumrow.S_IS_CAT -->
		<!-- EVENT forumlist_body_forum_row_before -->
But in your stylesheet use the li
li.newpost {
Remember to clear server cache and you should be good.
If you still have problems use the !important in your css
li.newpost {
	background-color: #aaffff !important;
TWEagle
Post by TWEagle »
I have done it with the important but no difference
:S
I don't understand it
Maybe someone needs to make a post or a reply in a topic that you have not read. Are you not waiting for a new post.
TWEagle
Post by TWEagle »
I have a test topic where I have logged in with another account
Are you refreshing your browser to see the change?
Is cssmagic controlling the background color using !important?
Disable magic to check that.
Do you have another extension controlling that background?
Are you editing the wrong files?
You need to find out what's going on on your end because the codes are solid.
He is not a magic user unless using the old outdated free version.
TWEagle
Post by TWEagle »
martin wrote: Apr 2nd, '20, 18:09 He is not a magic user unless using the old outdated free version.
I haven't got indeed the magic css
TWEagle wrote: Apr 2nd, '20, 13:51 I have a test topic where I have logged in with another account
Magic is not going to make the background work. Did you get that working?
TWEagle
Post by TWEagle »
Sniper_E wrote: Apr 5th, '20, 18:12
not yet
