Off-TopicExtending Advertisement Template Locations
All the various Off-Topic crap here ;)
Exabot
    Mac OS X Firefox
Post by Exabot »
Can anyone help me with this?
I only need banners to appear on the front page (index_body.html), but I can't get it to work… :sad:
Extension is Advertisement Management.
The Advertisement Management extension allows you, extension developers, to add new template locations for advertisements to display. To do this in your extensions, follow these simple instructions:
1. In your config/services.yml, add new location declaration like this:
demo.extension.location.type.location_name:
        class: demo\extension\location\type\location_name
        arguments:
            - '@user'
            - '@language'
        tags:
            - { name: phpbb.ads.location.type }
  • Always prefix the location type with your vendor and extension name.
  • Tag is crucial here and must be named phpbb.ads.location.type
2. Add a location type class in location/type/ directory, for example location_name.php.
  • It must implement \phpbb\ads\location\type\type_interface.
  • We strongly encourage you to extend \phpbb\ads\location\type\base.
3. Implement required methods.
  • See \phpbb\ads\location\type\type_interface for their descriptions.
  • Regarding get_id(), we strongly suggest using your vendor and extension name as a prefix, i.e.:
public function get_id()
        	return 'demo_extension_location_name';
  • Please note, that when you inherit from \phpbb\ads\location\type\base, you don’t need to bother with get_name() and get_desc() methods when you use proper language keys as such (where <location id> is a capitalized form of get_id()):
  • AD_<location id> for location name
  • AD_<location id>_EXPLAIN for location description
4. Implement optional method will_display(). If your location is not present on every page, we strongly encourage you to implement this method.
  • You can use $this->user->page['page_name'], $this->user->page['query_string'] or any other techniques to decide whether your location should display on a given page.
  • Don’t perform resource-expensive calculations here, such as DB requests - the intention is to speed up the page load, not the opposite.
  • See our default locations for examples.
  • This can improve the extension’s performance and will be appreciated by the users.
5. Load language file.
  • If inheriting from \phpbb\ads\location\type\base, the language file must contain two language keys:
  • AD_<location id>
  • You can define these in any language file and load your language file by any means in your extension.
  • If you do not already have any language files in your extension, or want to load a language file just for your ad locations, you may do so by adding it to your location class constructor, for example:
public function __construct(\phpbb\user $user, \phpbb\language\language $language)
            parent::__construct($user, $language);
            $this->language->add_lang('locations', 'demo/extension');
6. Add template event. Simply create a template event for the desired position and add this code into it:
{% set PHPBB_ADS_STYLE = 'margin: 0;' %}
    {% set PHPBB_ADS_CODE, PHPBB_ADS_ID = AD_DEMO_EXTENSION_LOCATION_NAME, AD_DEMO_EXTENSION_LOCATION_NAME_ID %}
    {% include '@phpbb_ads/phpbb_ads_default.html' ignore missing %}
  • Use PHPBB_ADS_STYLE to give your advertisement container a customized set of CSS.
  • Regarding PHPBB_ADS_CODE and PHPBB_ADS_ID, you should not alter the logic of these variables as they are used internally within the default ads template file - simply use AD_ prefix, your capitalized result of get_id(), and append the second one with _ID.
  • Note the ignore missing is an important function that will allow your extension to work even if phpbb/ads is disabled or uninstalled.
7. You are done!
a. Enable your extension.
b. Head to ACP -> Extensions -> Advertisement Management -> Manage Advertisements -> Add new advertisement, scroll down to Locations and you should see your new location present and functional.
8. Bonus: If you want to prevent people from being able to install your extension if phpBB’s Advertisement Management extension is not installed yet, add the following to your ext.php:
public function is_enableable()
    	return $this->container->has('phpbb.ads.listener');
demo.zip
Re: Extending Advertisement Template Locations
Will install this later today.
If it's just show it on index only you could just use an if statement to do it.
Exabot
Post by Exabot »
Probably it would work, but I guess I'm doing something wrong...
I would be very grateful if you could find any solution to display banners only on the front page. :buigen:
Exabot
Post by Exabot »
ivailo95 wrote: Mar 23rd, '20, 11:09 try this one
Exchange of banners
That's not quite it. On phones, banners are incomplete and appear outside the front page. Two banner options are few.
Otherwise interesting solution, Thanks! :thumbup:
Exabot
Post by Exabot »
Has anyone had time to try it? :smile:
Yes i have where is the original files ? the ext.php will not install.
Exabot
Post by Exabot »
Original files.
ads.zip
Like this ? http://www.the-chinese-diesel-heater-community.com/ i used a logo image and it only shows on the index.
martin wrote: Mar 25th, '20, 12:32 Like this ? http://www.the-chinese-diesel-heater-community.com/ i used a logo image and it only shows on the index.
looks ok on index only.
Try this every thing is set to show on index only also now installs on 3.3 aswell.
phpbb_ads_2_0_3.zip
Exabot
Post by Exabot »
Looks like it works. :tumbsyes:
Will it work through this phpbb ads ext?
Otherwise I would have liked that:
Try it and see i dont use add's so dont know a great deal how they work.
Exabot
Post by Exabot »
After Header Navbar - This option does not hide the banner. Others works perfectly! :thumbup:
I'll try more in the evening.
What exactly did you change? Then I know if I need to adjust.
Cool il fix that one too and give new files.
