Support Request Support3.2.1 to 3.3 upgrade seems to go haywire
Support Section
Anuj Dhawan
Post by Anuj Dhawan »
Your phpBB Version: phpBB3.2.1
Your knowledge: Beginner
Boardlink: www.zmainframes.com
PHP Version: 7.1
Tried to upgrade from phpBB 3.2.1 to phpBB 3.3
Tried to disable the extension, but ACP is not accessible
This is the error I'm getting into, could you please help:
Fatal error: Uncaught InvalidArgumentException: The routing file "/home4/anujdhaw/public_html/ext/dmzx/hangman/config/routing.yml" contains unsupported keys for "dmzx_hangman_main_controller": "pattern". Expected one of: "resource", "type", "prefix", "path", "host", "schemes", "methods", "defaults", "requirements", "options", "condition", "controller". in
Re: 3.2.1 to 3.3 upgrade seems to go haywire
Hm
seems you are deleted a extension without clear data or without disable it :roll:
A lot of extensions are not setup to run on 3.3 because the .yml needs to be written differently.
There is a yml checker extension that could have told you which extensions were not valid foe 3.3
Then you could have disabled those extensions and deleted data before you upgraded to 3.3
Can you revert back to 3.2.1 and start over?
Anuj Dhawan
PhpBB "Automatic updater" seems to work intelligently. It disabled all the extensions and that solved it for now. I can got to ACP and board is functional.
