Solved QuestionsCant login
Cant login
Just installed phpbb now cant login ? easy fix your cookie or paths are wrong.
the cookie must have a dot in front example .mysite.com
and make sure both paths are also correct.
Download this file place it in your root (where your config.php is)
cookie.zip
Now call the file example mysite.com/cookie.php enter the right details if done right you can now login.
image for example only
Dont forget to remove this file once done or any one could change your info.
This topic has 5 replies
Register Logout
