3.2 & 3.3 Extensions DatabaseReading progressbar
Magic user status: Online
Reading progressbar
Extension Name: Reading progressbar
This extension will add a reading progressbar, selectable colour and position in ACP.
- js update
Reading progressbar v1.0.1
Try this version if the one above fails to work.
  2. Unzip the downloaded release, and change the name of the folder to `progressbar`.
  4. Copy the `progressbar` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/progressbar/composer.json
  6. Look for `Reading progressbar` under the Disabled Extensions list, and click its `Enable` link.
This topic has 20 replies
Register Logout
