Generalsidebar menu
General information
kaptangula
sidebar menu
Post by kaptangula »
Sidebar manu help
Re: sidebar menu
It would help if you explained what you want no one is going to answer you with a 3 word post.
kaptangula
Re: sidebar menu
Do you know what the model needs as in the picture
Re: sidebar menu
You want that sidebar? That's from the Board3 Portal.
phpBB 3.2 portal: https://www.solidjeuh.be/scripts/board3.zip
kaptangula
Re: sidebar menu
Like this but without portal
or how to remove portal from header menu
Re: sidebar menu
