Off-TopicIphone - mchat
All the various Off-Topic crap here ;)
lopoto
    Mac OS X iPhone
Iphone - mchat
Post by lopoto »
I can not send any posts in the mchat of the iphone
Magic user status: Online
Re: Iphone - mchat
Hate iphone thats why :rolling:
lopoto
Re: Iphone - mchat
Post by lopoto »
dmzx wrote: Aug 11th, '18, 15:13 Hate iphone thats why :rolling:
this is the ext problem. Countdown ,probably because when I added it, I had the same problem :coffee:
Re: Iphone - mchat
Yes if countdown ext enabled then iphone users have trouble posting into mchat.
Advice to board owners pm your users andd tell them iphones are shit dont be so tight go buy a real phone.
lopoto
Re: Iphone - mchat
Post by lopoto »
martin wrote: Aug 12th, '18, 19:24 yes if countdown ext enabled then iphone users have trouble posting into mchat.
funy boy :rolling:
rogger007
Re: Iphone - mchat
Post by rogger007 »
I am also facing the same problem.
Yayer2020
Re: Iphone - mchat
Post by Yayer2020 »
I got the same error
Re: Iphone - mchat
Unistall the countdown then it is iphones fault for having crap apps.
There is many things the iphone wont work on due to the ability of the way there apps are written.
Shinikiri
    Mac OS X iPhone
Re: Iphone - mchat
Post by Shinikiri »
I have two phone,an iphone11 and Pixel2XL,upload some files to ftp ,the iphone is difficult to do it,files-import to zip software-unzip-repack-files-upload. If you don’t use filza for jailbreaking, it will be difficult for Apple to use. sofor lot of my website uploading,i choose pixel for that...
[ Posted using my iPhone ]
