Support Request SupportUlimate points User Logs
Support Section
Ruud66
    Windows 7 Internet Explorer
Post by Ruud66 »
Your phpBB Version: 3.2.2
Extensions installed: No
Boardlink: https://www.spelletjes4u.nl
PHP Version: 7.2
Uninstall and reinstall
I have a little problem:
When I try to delete the user logs, I get the next error:
Algemene fout
SQL ERROR [ mysqli ]
You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near '' at line 1 [1064]
SQL
TRUNCATE TABLE
BACKTRACE
FILE: (not given by php)
LINE: (not given by php)
CALL: msg_handler()
LINE: 996
CALL: trigger_error()
LINE: 193
LINE: 329
FILE: [ROOT]/ext/dmzx/ultimatepoints/controller/admin_controller.php
LINE: 223
CALL: phpbb\db\driver\factory->sql_query()
FILE: [ROOT]/ext/dmzx/ultimatepoints/acp/acp_ultimatepoints_module.php
LINE: 34
CALL: dmzx\ultimatepoints\controller\admin_controller->display_points()
LINE: 676
CALL: dmzx\ultimatepoints\acp\acp_ultimatepoints_module->main()
FILE: [ROOT]/adm/index.php
LINE: 82
CALL: p_master->load_active()
Thanks in advance for your help and kind regards,
Ruud66
Re: Ulimate points User Logs
This will be solved in next release.
Ruud66
Post by Ruud66 »
That's great and thanks for your very quick reply!
Kind regards,
Ruud
