Various modifications for phpBB3Mp3 attachment/bbcode
Snippets for phpBB3
Magic user status: Online
Open: includes/constants.php
define('ATTACHMENT_CATEGORY_QUICKTIME', 6); // Quicktime/Mov files
define('ATTACHMENT_CATEGORY_MP3', 7); // MP3 Files - Streaming
Open: includes/functions_content.php
 // Windows Media Streams
                case ATTACHMENT_CATEGORY_WM:
                   $l_downloaded_viewed = 'VIEWED_COUNT';
                   // Giving the filename directly because within the wm object all variables are in local context making it impossible
                   // to validate against a valid session (all params can differ)
                   // $download_link = $filename;
                   $block_array += array(
                      'U_FORUM'      => generate_board_url(),
                      'ATTACH_ID'      => $attachment['attach_id'],
                      'S_WM_FILE'      => true,
                   // Viewed/Heared File ... update the download count
                   $update_count[] = $attachment['attach_id'];
                break;
// MP3 Streams
                   case ATTACHMENT_CATEGORY_MP3:
                         'S_MP3_FILE'      => true,
                   break;
Open: includes/acp/acp_attachments.php
$cat_lang = array(
                   ATTACHMENT_CATEGORY_NONE      => $user->lang['NO_FILE_CAT'],
                   ATTACHMENT_CATEGORY_IMAGE      => $user->lang['CAT_IMAGES'],
                   ATTACHMENT_CATEGORY_WM         => $user->lang['CAT_WM_FILES'],
                   ATTACHMENT_CATEGORY_RM         => $user->lang['CAT_RM_FILES'],
                   ATTACHMENT_CATEGORY_FLASH      => $user->lang['CAT_FLASH_FILES'],
                   ATTACHMENT_CATEGORY_QUICKTIME   => $user->lang['CAT_QUICKTIME_FILES'],
ATTACHMENT_CATEGORY_MP3         => $user->lang['CAT_MP3_FILES'],
$types = array(
Open: language/en/acp/attachments.php
 'CAT_QUICKTIME_FILES'      => 'Quicktime media files',
'CAT_MP3_FILES' => 'MP3',
Open: styles/prosilver/template/attachment.html
                   // <![CDATA[
                       if (document.rmstream_{_file.ATTACH_ID}.GetClipWidth)
                           while (!document.rmstream_{_file.ATTACH_ID}.GetClipWidth())
                           var width = document.rmstream_{_file.ATTACH_ID}.GetClipWidth();
                           var height = document.rmstream_{_file.ATTACH_ID}.GetClipHeight();
                           document.rmstream_{_file.ATTACH_ID}.width = width;
                           document.rmstream_{_file.ATTACH_ID}.height = height;
                           document.ctrls_{_file.ATTACH_ID}.width = width;
                   </script>
<!-- ELSEIF _file.S_MP3_FILE -->
       <object type="application/x-shockwave-flash" data="mediaplayer/mp3player/player.swf" id="audioplayer1" height="24" width="290">
       <param name="movie" value="mediaplayer/mp3player/player.swf" />
       <param name="FlashVars" value="playerID=1&soundFile={_file.U_DOWNLOAD_LINK}" />
       <param name="quality" value="high" />
       <param name="menu" value="true" />
       <param name="wmode" value="transparent" />
       </object><br/>
       <span class="gensmall">
           <!-- IF _file.UPLOAD_ICON -->{_file.UPLOAD_ICON} <!-- ENDIF -->
       <a href="{_file.U_DOWNLOAD_LINK}">{_file.DOWNLOAD_NAME}</a><br/> [ {_file.FILESIZE} {_file.SIZE_LANG} | {_file.L_DOWNLOAD_COUNT} ] </span>
The easiest part!
Open phpBB3 Admin Control Panel
Go to the posting tab
Under “Manage Extension Groups” add “Files MP3″, select the “MP3″ for a special category and any other settings that you like.
Under “Manage Extensions” add “mp3″ under the group “files MP3″.
Under “Manage Extensions” verify that the “MP3″ extension is filed under “Files MP3”.
Step 5: MP3 BBCode
Not necessary, only if you want to be able to move the flash player to different forums.
Navigate to Posting BBcodes.
BBCode usage
[mp3]{URL}[/mp3]
HTML replacement
<object type="application/x-shockwave-flash" data="http://yourwebsiteurl.com/player.swf" id="audioplayer1" height="24" width="290">
       <param name="movie" value="http://yourwebsiteurl.com/player.swf" />
       <param name="FlashVars" value="playerID=1&soundFile={URL}" />
       </object>
Help Line
 [mp3]URL to file[/mp3]
That’s it!
place this folder in root
root(1).zip
Re: Mp3 attachment/bbcode
I'l update this for 3.2 if it needs it as the site it come from is now gone.
martin wrote: Jun 28th, '16, 22:45 I'l update this for 3.2 if it needs it as the site it come from is now gone.
zardos
Post by zardos »
Thanks martin and DM :thumbup:
