Support Request SupportI have problem with mchat
Support Section
Your phpBB Version: 3.2.2
Your knowledge: Beginner
Boardlink: http://galacticmassive.kefcheto.eu/index.php
PHP Version: 5.6.33
MySQL Version: idk
well just look for update and i suspect mchat not work so good as before
and tryed to update
um yea i just clear cache and seassons
i use this version of mchat now
can you help me?
Re: I have problem with mchat
I have problems with cold weather...
mChat works good.
If you want to get German translations for extensions: ask me. Deutscher Arcade Wiki im Aufbau
How can i fix this problem?
Use this and type your error in it.
martin wrote: Feb 18th, '18, 14:46 Use this and type your error in it.
when i typed this
No route found for "POST /mchat": Method Not Allowed (Allow: GET, HEAD)
See this
i check all page in mchat discuss release and still can't found how to solve my proble...
Took me less than 10 seconds to find your problem https://www.phpbb.com/customise/db/exte ... pic/186041
martin wrote: Feb 18th, '18, 16:44 Took me less than 10 seconds to find your problem https://www.phpbb.com/customise/db/exte ... pic/186041
i did like in the topic u gave me
so..
{% if MCHAT_PAGE == 'archive' or not (MCHAT_ALLOW_USE and S_BBCODE_ALLOWED) %}
	{% INCLUDEJS T_ASSETS_PATH ~ '/javascript/editor.js' %}
{% endif %}
{% INCLUDEJS '@dmzx_mchat/javascript/jquery.autogrow-textarea.js' %}
{% INCLUDEJS '@dmzx_mchat/javascript/jquery.titlealert.min.js' %}
{% INCLUDEJS '@dmzx_mchat/javascript/mchat.js' %}
	// <![CDATA[
	var form_name = 'postform';
	var text_name = 'message';
	var mChat = {
		// General settings
		actionUrls		: {
			{% for mchaturl in loops.mchaturl %}
				{{ mchaturl.ACTION }}: '{{ mchaturl.URL }}'{{ loop.last ? '' : ',' }}
			{% endfor %}
		page			: '{{ MCHAT_PAGE | escape('js') }}',
		cookie			: '{{ COOKIE_NAME | escape('js') }}',
		pause			: {{ MCHAT_PAUSE_ON_INPUT ? 'true' : 'false' }},
		playSound		: {{ MCHAT_SOUND ? 'true' : 'false' }},
		messageTop		: {{ MCHAT_MESSAGE_TOP ? 'true' : 'false' }},
		allowBBCodes	: {{ S_BBCODE_ALLOWED ? 'true' : 'false' }},
		liveUpdates		: {{ MCHAT_LIVE_UPDATES ? 'true' : 'false' }},
		relativeTime	: {{ MCHAT_RELATIVE_TIME ? 'true' : 'false' }},
		showCharCount	: {{ MCHAT_CHARACTER_COUNT ? 'true' : 'false' }},
		// Limits & timeouts
		refreshTime		: {{ MCHAT_REFRESH_JS }},
		whoisRefresh	: {{ MCHAT_WHOIS_REFRESH }},
		timeout			: {{ MCHAT_TIMEOUT }},
		mssgLngth		: {{ MCHAT_MESSAGE_LNGTH }},
		editDeleteLimit	: {{ MCHAT_EDIT_DELETE_LIMIT }},
		logId			: {{ MCHAT_LOG_ID }},
		removeBBCodes	: '{{ MCHAT_DISALLOWED_BBCODES | escape('js') }}',
		// Language
 		lang: {
 			minutesAgo		: {
				{% if MCHAT_RELATIVE_TIME %}
					{% for minute in 0..MCHAT_MINUTES_AGO_LIMIT-1 %}
						{{ minute }}: '{{ lang('MCHAT_MINUTES_AGO', minute) | escape('js') }}'{{ loop.last ? '' : ',' }}
					{% endfor %}
				{% endif %}
 			err				: '{{ lang('ERROR') | escape('js') }}',
 			parserErr		: '{{ lang('AJAX_ERROR_TEXT_PARSERERROR') | escape('js') }}',
			newMessageAlert	: '{{ lang('MCHAT_NEW_CHAT') | escape('js') }}',
			noMessageInput	: '{{ lang('MCHAT_NOMESSAGEINPUT') | escape('js') }}',
			editInfo		: '{{ lang('MCHAT_EDITINFO') | escape('js') }}',
			delConfirm		: '{{ lang('MCHAT_DELCONFIRM') | escape('js') }}',
			sessOut			: '{{ lang('MCHAT_SESSION_OUT') | escape('js') }}',
			sessEnds		: '{{ lang('MCHAT_SESSION_ENDS_JS') | escape('js') }}',
			mention			: '{{ lang('MCHAT_MENTION') | escape('js') }}',
			refreshYes		: '{{ lang('MCHAT_REFRESH_YES', MCHAT_REFRESH_RATE) | escape('js') }}',
			refreshNo		: '{{ lang('MCHAT_REFRESH_NO') | escape('js') }}',
			charCount		: '{{ lang(MCHAT_MESSAGE_LNGTH ? 'MCHAT_CHARACTER_COUNT_LIMIT' : 'MCHAT_CHARACTER_COUNT') | escape('js') }}',
			mssgLngthLong	: '{{ lang('MCHAT_MESS_LONG', MCHAT_MAX_MESSAGE_LENGTH) | escape('js') }}',
			likes			: '{{ lang('MCHAT_LIKES') | escape('js') }}'
</script>
Purged the cache and seasson and still have this problem..
:wall: It does not say edit any files you need to read :whistl:
martin wrote: Feb 18th, '18, 21:14 :wall: It does not say edit any files you need to read :whistl:
then what it says?
ivailo95 wrote: Feb 18th, '18, 22:38
then what it says?
by Binano » Sat Dec 09, 2017 2:12 pm
I have reinstalled mChat 2.0.1, actived, erased, reinstalled mchat 2.0.2... and now, it's ok !
Thanks !
martin wrote: Feb 18th, '18, 23:35
then what it says?
Thanks !
well..i did the same thing but still have this problem
and purged the cache and seassion
dmzx can you help me with this problem? :eyes2: :question: :whistl: :roll: :???:
If you cant solve a simple problem like that you may need to think about paying some one to fix it for you there is plenty of folks out there who will/or have the time to fix it (the problem is not mchat or phpbb) its user error.
martin wrote: Feb 21st, '18, 01:20 If you cant solve a simple problem like that you may need to think about paying some one to fix it for you there is plenty of folks out there who will/or have the time to fix it (the problem is not mchat or phpbb) its user error.
hm :question: what kind of user error?
i mean ..something in code or ?
:question: :question: :eyes2:
i use mchat in this forum
http://test.kefcheto.eu/index.php?sid=7 ... 427b4a27e7
and work good
but in this one http://galacticmassive.kefcheto.eu/inde ... ad997d7670 can't use it cuz it's error..
both it are phpbb 3.2.2
