Phpbb 3.2.1 i have log in show this problem any one help me thanks.
No route found for "POST /ucp.php
3.2.x 3.2.x Snippets ⇒ phpbb 3.2.1 log in problem
- Magic user status: Offline
Re: phpbb 3.2.1 log in problem
These are both likely to be caused by your hosts mod_security server settings. , I suggest you contact them and see if they can disable some settings.
* copied from phpbb forums . something I have been doing for awhile now is, ' copy past the errors u get into google search ' usually get a list of related topics.
** martin posted somehwere a temporary " GET " fix , not sure if can apply to this, I will try look for it .
Jesterdisable gzip compression. chances are that your server is already using it and having it turned on in phpbb as well can cause problems.
also, change the force url settings from yes to no.
that is only for situations where the server setup is strange and phpbb can not find itself.
after that, purge the cache and then see what happens.
if that doesn't fix it, tell us what extensions if any that you have installed and exactly how you did the upgrade.
of most importance is did you completely remove all old MODs that you had installed and did you completely replace all old files except for the config.php file.
Illegal use of _GET, _POST, _SERVER
Originally posted by martin
Quick fix if your using none related files to phpbb. (note this is a temp fix)
