3.2.x 3.2.x SnippetsProfile cover and header like IPB 4 for phpbb 3.2
Snippets
salazardeaguiar
Post by salazardeaguiar »
Hi guys, I'm from the "phpbb Brazil Support" team and I developed a tutorial there on the site for profile cover and header similar to IPBoard 4.2.x using profile fields. The original post link is this: http://www.suportephpbb.com.br/viewtopi ... 69&t=49558
I will translate it so that you can take advantage and leave your suggestions:
This tutorial, in its previous version, was intended to teach you how to manually make a profile cover for your forum phpbb 3.1.x or 3.2.x using custom profile fields. For a while I improved some things and I tried to bring a header very similar to ipboard, so that it is complete. Let's use the prosilver style as a basis.
RECOMMENDATION: Although we will use prosilver, we do not recommend making changes to the default phpbb style. This is because, when updating, you will lose your changes in file substitutions. Ideally you create a style based on prosilver and make all changes in it.
CREATING THE COVER - ACP PROFILE FIELD
Go to ACP > USERS AND GROUPS > Custom profile fields.in the footer, set the name to capa and choose the type URL (link), as shown in the image below. Then click Create new field.
On the next screen, just check the Display in user control panel:
In the next screen, under Options specific to the profile type, you can leave as the image shows.
Save your new profile field. Do not forget, his name is capa
IN TEMPLATE
Remember, we are using a prosilver-based template, so if you do not find the codes below it is possible that your style will be greatly modified.
Open root/styles/seuestilo/template/memberlist_view.html
FIND:
<!-- BEGIN custom_fields -->
			<!-- IF not custom_fields.S_PROFILE_CONTACT -->
REPLACE WITH:
		<!-- IF not custom_fields.S_PROFILE_CONTACT and not custom_fields.S_PROFILE_CAPA  -->
FIND:
<div class="panel bg1<!-- IF S_ONLINE --> online<!-- ENDIF -->">
REPLACE WITH:
<div class="panel bg1">
FIND:
<!-- IF AVATAR_IMG -->
		<dl class="left-box">
			<dt class="profile-avatar">{AVATAR_IMG}</dt>
			<!-- EVENT memberlist_view_rank_avatar_before -->
			<!-- IF RANK_TITLE --><dd style="text-align: center;">{RANK_TITLE}</dd><!-- ENDIF -->
			<!-- IF RANK_IMG --><dd style="text-align: center;">{RANK_IMG}</dd><!-- ENDIF -->
			<!-- EVENT memberlist_view_rank_avatar_after -->
		</dl>
	<dl class="left-box details profile-details">
		<dt>{L_USERNAME}{L_COLON}</dt>
		<dd>
			<!-- IF USER_COLOR --><span style="color: {USER_COLOR}; font-weight: bold;"><!-- ELSE --><span><!-- ENDIF -->{USERNAME}</span>
			<!-- IF U_EDIT_SELF --> [ <a href="{U_EDIT_SELF}">{L_EDIT_PROFILE}</a> ]<!-- ENDIF -->
			<!-- IF U_USER_ADMIN --> [ <a href="{U_USER_ADMIN}">{L_USER_ADMIN}</a> ]<!-- ENDIF -->
			<!-- IF U_USER_BAN --> [ <a href="{U_USER_BAN}">{L_USER_BAN}</a> ]<!-- ENDIF -->
			<!-- IF U_SWITCH_PERMISSIONS --> [ <a href="{U_SWITCH_PERMISSIONS}">{L_USE_PERMISSIONS}</a> ]<!-- ENDIF -->
		</dd>
		<!-- IF not AVATAR_IMG -->
			<!-- EVENT memberlist_view_rank_no_avatar_before -->
			<!-- IF RANK_TITLE --><dt>{L_RANK}{L_COLON}</dt> <dd>{RANK_TITLE}</dd><!-- ENDIF -->
			<!-- IF RANK_IMG --><dt><!-- IF RANK_TITLE -->&nbsp;<!-- ELSE -->{L_RANK}{L_COLON}<!-- ENDIF --></dt> <dd>{RANK_IMG}</dd><!-- ENDIF -->
			<!-- EVENT memberlist_view_rank_no_avatar_after -->
		<!-- IF S_USER_INACTIVE --><dt>{L_USER_IS_INACTIVE}{L_COLON}</dt> <dd>{USER_INACTIVE_REASON}</dd><!-- ENDIF -->
		<!-- IF AGE !== '' --><dt>{L_AGE}{L_COLON}</dt> <dd>{AGE}</dd><!-- ENDIF -->
		<!-- IF S_GROUP_OPTIONS --><dt>{L_USERGROUPS}{L_COLON}</dt> <dd><select name="g">{S_GROUP_OPTIONS}</select> <input type="submit" name="submit" value="{L_GO}" class="button2" /></dd><!-- ENDIF -->
		<!-- EVENT memberlist_view_non_contact_custom_fields_before -->
				<dt>{custom_fields.PROFILE_FIELD_NAME}{L_COLON}</dt> <dd>{custom_fields.PROFILE_FIELD_VALUE}</dd>
		<!-- END custom_fields -->
		<!-- EVENT memberlist_view_non_contact_custom_fields_after -->
		<!-- EVENT memberlist_view_zebra_before -->
		<!-- IF S_USER_LOGGED_IN and S_ZEBRA -->
			<!-- IF U_REMOVE_FRIEND -->
				<dt>&nbsp;</dt> <dd class="zebra"><a href="{U_REMOVE_FRIEND}" data-ajax="zebra"><strong>{L_REMOVE_FRIEND}</strong></a></dd>
			<!-- ELSEIF U_REMOVE_FOE -->
				<dt>&nbsp;</dt> <dd class="zebra"><a href="{U_REMOVE_FOE}" data-ajax="zebra"><strong>{L_REMOVE_FOE}</strong></a></dd>
			<!-- ELSE -->
				<!-- IF U_ADD_FRIEND -->
					<dt>&nbsp;</dt> <dd class="zebra"><a href="{U_ADD_FRIEND}" data-ajax="zebra"><strong>{L_ADD_FRIEND}</strong></a></dd>
				<!-- IF U_ADD_FOE -->
					<dt>&nbsp;</dt> <dd class="zebra"><a href="{U_ADD_FOE}" data-ajax="zebra"><strong>{L_ADD_FOE}</strong></a></dd>
		<!-- EVENT memberlist_view_zebra_after -->
	</dl>
REPLACE WITH:
<!-- INÍCIO DO HEADER -->
<div class="capa-de-perfil-imagem">
<!-- IF S_PROFILE_CAPA -->
	<img src="{PROFILE_CAPA_VALUE_RAW}" class="header-customizado" />
<!-- ELSE -->
	<img src="{T_THEME_PATH}/images/no_cover.jpg" class="header-customizado" />
<!-- Início da coluna com avatar e informações -->
	<div class="colunaPerfil">
		<div style="display:block" class="colunaAvatar">
					{AVATAR_IMG}
			<!-- ELSE -->
					<img src="{T_THEME_PATH}/images/no_avatar.gif" />
		</div>
		<strong class="box-nick box-user"><!-- IF S_ONLINE --><i id="online" class="fa fa-circle" aria-hidden="true" title="Online"></i><!-- ELSE --><i id="offline" class="fa fa-circle" aria-hidden="true" title="Offline"></i><!-- ENDIF --><span style="vertical-align:middle;display:inline;">{USERNAME}</span></strong>
		<br/><br/>
		<strong class="box-nick" style="line-height:0px;font-size:17px">{RANK_TITLE}</strong>
		<br><br><br>
			<!-- IF U_REMOVE_FRIEND --><a href="{U_REMOVE_FRIEND}" data-ajax="zebra" class="hide-mobile button"><i class="fa fa-minus-circle"></i><span>{L_REMOVE_FRIEND}</span></a><!-- ELSEIF U_REMOVE_FOE --><a href="{U_REMOVE_FOE}" data-ajax="zebra" class="hide-mobile button"><i class="fa fa-minus-circle"></i><span>{L_REMOVE_FOE}</span></a><!-- ELSE --><!-- IF U_ADD_FRIEND --><a href="{U_ADD_FRIEND}" data-ajax="zebra" class="hide-mobile button"><i class="fa fa-smile-o"></i><span>{L_ADD_FRIEND}</span></a><!-- ENDIF --><!-- IF U_ADD_FOE --><a href="{U_ADD_FOE}" data-ajax="zebra" class="hide-mobile button"><i class="fa fa-frown-o"></i><span>{L_ADD_FOE}</span></a><!-- ENDIF --><!-- ENDIF -->
			<a href="{U_EDIT_SELF}" class="hide-mobile button"><i class="fa fa-pencil-square-o" aria-hidden="true"></i><span>{L_EDIT_PROFILE}</span></a>
			<a href="{U_USER_ADMIN}" class="hide-mobile button"><i class="fa fa-pencil" aria-hidden="true"></i><span>{L_USER_ADMIN}</span></a>
			<a href="{U_USER_BAN}" class="hide-mobile button"><i class="fa fa-ban" aria-hidden="true"></i><span>{L_USER_BAN}</span></a>
			<a href="{U_SWITCH_PERMISSIONS}" class="hide-mobile button"><i class="fa fa-user" aria-hidden="true"></i><span>{L_USE_PERMISSIONS}</span></a>
	</div>
</div>
<!-- FIM DO HEADER -->
If you prefer, create a file called custom.css. If not, use the common.CSS
Open root/styles/seuestilo/theme/common.css
ADD ANYWHERE, OF PREFERENCE AT THE END[/c]
/* Capa de perfil por LucasLV */
@media (max-width: 700px) {
	.capa-de-perfil-imagem {
		height: auto;
@media (min-width: 700px) {
		height: 310px;
	.hide-mobile {
		display: none;
  width: 100%;
  overflow: hidden;
  position: relative;
.capa-de-perfil-imagem > .header-customizado {
  width: 100%;
.colunaPerfil {
	color: #fff;
	padding: 12px;
	position: absolute;
	bottom: 0;
	left: 0;
	width: 100%;
	min-height: 80px;
	box-sizing: border-box;
	flex-direction: row;
	flex: 0;
	flex-wrap: nowrap; }
.colunaAvatar {
	top: 15px;
	left: 10px;
	width: 130px;
	height: 130px;
	overflow:hidden;
	margin-right:19px;
	float: left; }
.colunaAvatar img {
	width: 130px;
	height: auto;
#online {
	color: #228B22;
	font-size: 27px;
	vertical-align: middle;
	margin-right: 6px;
#offline {
	color: #BEBEBE;
	font-size: 27px;
	margin-right: 6px;
.box-nick {
	background-color: rgba(0,0,0,.3);
	padding: 7px 10px;
	text-shadow: 0px 0px 4px rgba(0,0,0,0.5);
	width: auto;}
.box-user {
	color: #fff;
	font-size: 33px;
/* Fim do perfil */
Now, send the image no_cover.jpg for folder /theme/images to appear for users who do not have a profile layer defined.
Download below:
To set your profile cover, go to UCP - Profile
RESULTADOS:
With cover defined in UCP
WITHOUT COVER DEFINED IN UCP:
- It is responsive (by the tests that I did everything is well adjusted, but anything is just talking)
- I do not intend to launch in extension, because I do not even know how to do this
- The default header has height of 310pixels and has been set on the mobile phone so it does not cause those whitespace when setting height and width of an element at other resolutions. I do not fully dominate CSS, any suggestions are much more than welcome.
uruguayito
Re: Profile cover and header like IPB 4 for phpbb 3.2
Post by uruguayito »
Nice Snippet
thank you :thumbup:
I'm a latin american man.
Spanish is my language.
Barrybrennan
Post by Barrybrennan »
Were is the download link ? :eyes2:
Barrybrennan wrote: Oct 1st, '17, 13:51 were is the download link ? :eyes2:
There is none it's an edit not an ext.
martin wrote: Oct 1st, '17, 14:15
Look at this...
https://github.com/msaulohenrique/aps/r ... /tag/1.0.0
Do you mean this?
Bye Jan
Re: Profile cover and header like IPB 4 for phpbb 3 2
testmeml wrote: Apr 13th, '18, 10:50 Hi Movint
Please post in english here i dont understand your text
and other user
Yeah Movint post in english :wtf: who is Movint ? no one by that name posted in this topic. :rolling:
martin wrote: Apr 13th, '18, 16:56
and other user
Indeed also did not find that member... :shock:
Napster
Post by Napster »
Someone call mulder and scully we have a missing person :rolling: :whistl:
Aliens ? you think :eyes2:
Mr Fire
Post by Mr Fire »
This available for 3.2 the newer version?
mr.franta
Post by mr.franta »
Nice tutorial :)
d3ath2435
Post by d3ath2435 »
video?mode=view&id=262
I made some changes to the code and the visualization! I also made a video of the steps! I'm sorry it's not in your language, but the steps are shown and are easy to follow. :tumbsyes:
RazvanAlexandru
Post by RazvanAlexandru »
I was just lookinf for that, thank you
sickkick
Post by sickkick »
I encounter a problem with the script, I will post a screenshot here to show you what I mean https://i.ibb[dot]co/q7W0YC5/1.png
I want the buttons like edit profile and administer user to be a little bit more highlighted, because if it's another cover that it's white, the buttons will be almost invisible.
And also, if it's possible, the statistics from the profile layout to be a little bit more rearranged.
Thank you!
