3.2.x 3.2.x SnippetsphpBB syntax to template files using Twig syntax
Snippets
This is phpbb 3.2.1 default prosilver template files converted to phpBB Twig syntax there not needed right this moment but in the near future phpbb will be using them as standard.
Have a look and learn the new way of editing (you can use these files in 3.2.1 if you wanted to right now)
prosilver_twig_templates.zip
Galixte de EzCom
Re: phpBB syntax to template files using Twig syntax
Post by Galixte de EzCom »
Hi Martin,
thanks for information. Where is the discussion about that on phpBB.com or maybe it’s on area51 board ?
Communau EzCom
Image « Traductions d’extensions & styles pour phpBB 3.1.x & 3.2.x ».
Area51 i think.
Galixte de EzCom
I found this topic: [Tutorial] Convert to Twig Syntax | See the “Twig Converter” extension by Kasimi to convert all styles/extensions with Twig syntax.
Galixte de EzCom
