3.2 & 3.3 Extensions Database 3.2 / 3.3Groups Page
Groups Page
Extension Name: Groups Page
Author: dmzx & martin
Groups Page will add link in footer to show all groups of the board with members.
dmzx/Groups-Page
- Add option in ACP to select groups.
- Twig update.
Groups Page v1.0.1
  2. Unzip the downloaded release, and change the name of the folder to `groupspage`.
  4. Copy the `groupspage` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/groupspage/composer.json
  6. Look for `Groups Page` under the Disabled Extensions list, and click its `Enable` link.
eunaumtenhoid
Re: Groups Page
Post by eunaumtenhoid »
What's the difference to the team link?
Brazilian Portuguese translation by eunaumtenhoid (c) 2017 [ver 1.0.0]
https://github.com/phpBBTraducoes/groupspage
wads24
Re: Groups Page
Post by wads24 »
Is there a way to exclude certain groups from this page?
Re: Groups Page
wads24 wrote: 30 Aug 2018, 03:27 Is there a way to exclude certain groups from this page?
For now not...
Will check it.
wads24
Re: Groups Page
Post by wads24 »
dmzx wrote: 31 Aug 2018, 20:06
For now not...
Will check it.
Thank you very much DMZ. I just have so many members that yet wood just keep Printing and printing or printing
Naija
Re: Groups Page
Post by Naija »
Why is there no support for this ext? Especially it shouldn't be hard to exclude some groups.
Re: Groups Page
Naija wrote: 18 Jun 2021, 07:35 Why is there no support for this ext? Especially it shouldn't be hard to exclude some groups.
No it is not so hard to exclude the groups, but if you see the extra lines of code for it you will understand that its not just in a minute to add. :wink:
The new version is under test so will update this soon.
Re: Groups Page
Naija
Re: Groups Page
Post by Naija »
dmzx wrote: 18 Jun 2021, 11:33
Thanks for your work and efforts.
I'll test it out. Jah bless.
