Announcements for Dmzx-web.net
Magic user status:
Offline
Posts: 6081 Joined: Jan 13th, '14, 20:45
Post by dmzx » Jan 10th, '17, 10:22
Post
Translators wanted! fill in the form if you have the proper the requirements.
applicationform
grtz dmzx
stratege1401
Magic user status:
Offline
Posts: 2 Joined: Feb 1st, '15, 01:54
Post by stratege1401 » Feb 26th, '17, 21:42
Post
Hello DMZX...
was trying to apply to your call for translators, but:
No route found for "GET /applicationform" (from "
Translators wanted! ")
instead of your form.
Anyway, if you still need translations to FRENCH, be happy to help.
qnexo
Magic user status:
Offline
Posts: 17 Joined: Feb 26th, '17, 03:10
Post by qnexo » Feb 27th, '17, 01:51
Post
Form and non-functional error code
No route found for "GET /applicationform/viewtopic.php"
Tarkonte
Magic user status:
Offline
Posts: 14 Joined: Mar 5th, '17, 17:18
Post by Tarkonte » Apr 13th, '17, 08:16
Post
...same for me.
Available to support for Italian translations.
Cheers.
Magic user status:
Offline
Post by dmzx » Apr 13th, '17, 15:40
Post
Application is closed thats why the error will show.
But translators are still welcome
Will check it and revert soonest.
Funny
Magic user status:
Offline
Posts: 126 Joined: Mar 6th, '17, 15:39
Post by Funny » Apr 24th, '17, 21:53
Post
@ stratege 1401
The error no. route found for "GET /applicationform/viewtopic.php"
Look file just once in the composer.json
There can edit the error
The fault is due to the entry of web addresses and the e-mail address
Have had themselves the problem and corrected in this way
mg Funny
Salut
La route de no erreur trouvée pour « Se /applicationform/viewtopic.php »
Rechercher fichier qu’une seule fois dans le composer.json
Il peut modifier l’erreur
La faute est due à l’entrée des adresses web et l’adresse de messagerie
Avoir eu eux-mêmes le problème et corrigé de cette façon
olalavui
Magic user status:
Offline
Posts: 18 Joined: Jun 27th, '17, 20:00
Post by olalavui » Jul 1st, '17, 19:08
Post
Are you want translators for what?
Magic user status:
Offline
Posts: 4919 Joined: Apr 6th, '14, 14:12
Post by martin » Jul 1st, '17, 19:16
Post
To translate en lang files to your own lang.
Infi
Magic user status:
Offline
Posts: 3 Joined: Dec 3rd, '14, 22:16
Post by Infi » Jul 14th, '17, 11:31
Post
I can translate anything into polish if you give me VIP access.
dzyasseron
Magic user status:
Offline
Posts: 4 Joined: Dec 7th, '14, 16:06
Post by dzyasseron » Oct 6th, '17, 20:38
Post
Arabic
Magic user status:
Offline
Posts: 1070 Joined: Oct 14th, '14, 17:01
Post by Sniper_E » Oct 6th, '17, 22:48
Post
I can translate en to giberish.
[ Post made via Samsung Galaxy S5 Active ]
meis2m
Magic user status:
Offline
Posts: 33 Joined: Jul 24th, '17, 20:25
Post by meis2m » Oct 9th, '17, 06:24
Post
I am leader of Persian phpBB translators.
ninouee
Magic user status:
Offline
Posts: 29 Joined: May 1st, '16, 07:48
Post by ninouee » Nov 26th, '17, 20:42
Post
i have a french translation for ultimate points but i don't know how i cant upload it for you.
Can you help me?
Thank you.
Magic user status:
Offline
Posts: 309 Joined: Apr 6th, '15, 16:04
Post by Scanialady » Nov 27th, '17, 15:18
Post
You can use the "Attachments" function when you reply to a post, if you use the full editor (not quick reply)
ninouee
Magic user status:
Offline
Post by ninouee » Nov 27th, '17, 15:23
Post
I try to use it but it dont work because the forum dont see the extension of my files.
[ Post made via iPhone ]
