3.2.x Newsphpbb 3.2.0-RC2
News
phpbb 3.2.0-RC2
iorG19
Re: phpbb 3.2.0-RC2
Post by iorG19 »
I tried to made a update locally from 3.1.10 and i have blank_page. What should i do ?
“Si cres en tus fuerzas, nadie te podrá derrotar”Georgian Iordache // @iorG19 (GeorgioGalben)
Re: phpbb 3.2.0-RC2
Did you use the update package for 3.1.10 to 3.2.0-RC2?
Re: phpbb 3.2.0-RC2
Run this sitelink/install/app/php
iorG19
Re: phpbb 3.2.0-RC2
Post by iorG19 »
dmzx wrote: Dec 10th, '16, 15:21 Did you use the update package for 3.1.10 to 3.2.0-RC2?
Yes.
martin wrote: Dec 10th, '16, 15:23 run this sitelink/install/app/php
I will give a try right now.
(meanwhile)
Re: phpbb 3.2.0-RC2
Typo sitelink/install/app.php
iorG19
Re: phpbb 3.2.0-RC2
Post by iorG19 »
martin wrote: Dec 10th, '16, 15:31 typo sitelink/install/app.php
update finished; looks greate
i don't know what to do here, with ProSilver SE
iorG19
Re: phpbb 3.2.0-RC2
Post by iorG19 »
I disable it and deactivate, then i replace new files (3.2.0-RC1) and now it works.
Re: phpbb 3.2.0-RC2
Yes for every phpbb version there maybe a need for an updated style but in some cases a browser and boarc cache clear is some times needed.
As i suspect in this case a browser clear would have been enough.
