GeneralAdd extension to viewonline.php?
General information
Phpbb3
Post by Phpbb3 »
The puzzle extension doesn't show up in the who is online list, instead the location defaults to "index"... is there a way to add the path to the viewonline.php file? for example is there a way to make a simple case/break entry for the puzzle extension in the viewonline.php file? seems that all i would really need is the correct path and filename, no?
case 'webpage':
 $location = "great webpage";
 $location_url = append_sid("{$phpbb_root_path}webpage.$phpEx");
 break;
ps - i'm not woried about a language path, i'll just use "puzzle" for $location....
Phpbb3
Re: Add extension to viewonline.php?
Post by Phpbb3 »
Anyone?
Magic user status: Online
You need to add it in the puzzle listener.php.
Look here how its done for youtubegallery https://github.com/dmzx/youtubegallery/ ... r.php#L100
