3.1.x Extensions Database 3.1 / 3.2Page visits
Page visits
Extension Name: Page visits
This extension adds page visits in footer.
dmzx/Page-visits
Page visits v1.0.0
  2. Unzip the downloaded release, and change the name of the folder to `pagevisits`.
  4. Copy the `pagevisits` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/pagevisits/composer.json
  6. Look for `Page visits in footer` under the Disabled Extensions list, and click its `Enable` link.
cov182004
Re: Page visits
Post by cov182004 »
Works perfectly - thanks
Anuj Dhawan
Re: Page visits
Post by Anuj Dhawan »
Thanks! You inspire me to learn more of php and phpBB, well done!
By the way with with we_universal, it aligns to left. Please see, www.zmainframes.com - I think because it's how we universal sets anything in the footer. If we need to make it center aligned just for we_universal, what is the way to do it? Please advise.
Re: Page visits
A fine idea - very fine :)
I have installed this extension. Is it possible that counting does not work correctly if you change the style (Stylechanger, chatbox?)?
May be it counts more than one visit than (2-6). Or may be, my little site is overrunned and I don't know it... :rolling:
48 visits after 3 minutes... I can not believe :rolling:
Will check this with one of my test boards another day.
Thank you for this extension
martin Online
Re: Page visits
This detects the index so what ever hits the index also will show on other pages its not unique to all pages just the index.
Anuj Dhawan
Re: Page visits
martin wrote: 21 Jun 2016, 12:31 This detects the index so what ever hits the index also will show on other pages its not unique to all pages just the index.
So if add the "other page's count" as well, will not that be a true count of "visits"?
Re: Page visits
and what do you think about chatbox - actualizes every 10 seconds?
martin Online
Re: Page visits
Strange mine only goes up 1 number after a page refresh mchat has no effect on it.
public function page_footer($event)
		$pagevisits = (isset($this->config['pageviews'])) ? ($this->config['pageviews'] + 1) : 1;
		$this->config->set('pageviews', $pagevisits, 1);
		$pagevisits = number_format($pagevisits, 0, '.', ',');
			'PAGEVISITS'		=> $pagevisits,
Re: Page visits
I don't use mChat, but JV Footerchat and JV Chat. 2-7 calls one refresh of index page counted :whistl:
From yesterday in the evening to now: 9565 visits...
That is not correct, never :rolling:
May be we need restrictions - one person/guest/bot = one visit for x hours/minutes
Re: Page visits
:lol: will take a look at it.
moose5
Re: Page visits
Post by moose5 »
Scanialady wrote: 21 Jun 2016, 16:19 I don't use mChat, but JV Footerchat and JV Chat. 2-7 calls one refresh of index page counted :whistl:
Are you using tapatalk as well? Did 7 visits for every topic call I had on my forum.
Re: Page visits
No, I never have used tapatalk.
Anuj Dhawan
Re: Page visits
martin wrote: 21 Jun 2016, 14:03 strange mine only goes up 1 number after a page refresh mchat has no effect on it.
I also observe the same behavior as yours - a page refresh and count goes up by 1. I don't have mChat installed though.
As the "Windows Support representative" would say - close all the windows and restart... may be reinstall or Install on a test board without any other extension and observe the behavior.
Re: Page visits
Anuj Dhawan wrote: 22 Jun 2016, 08:32 ... may be reinstall or Install on a test board without any other extension and observe the behavior.
to install it on a test board without other extension may give the expected behaviour (because there is nobody else, too), but it is useless for me. :lol:
Re: Page visits
Scanialady wrote: 22 Jun 2016, 23:24
Did a quick look but the JV Chat does a POST every few seconds that will trigger the count.
Will check for a fix.
