Generaladmin notify
General information
moffacostanzo
admin notify
Post by moffacostanzo »
i installed this ext but when user register appeas this message
Fatal error: Uncaught exception 'Twig_Error_Loader' with message 'Unable to find template "@dmzx_notifyadmin/admin_notify_registered.txt" (looked into: ).' in /web/htdocs/www.openresource.it/home/phpbb/vendor/twig/twig/lib/Twig/Loader/Filesystem.php:195 Stack trace: #0 /web/htdocs/www.openresource.it/home/phpbb/phpbb/template/twig/loader.php(107): Twig_Loader_Filesystem->findTemplate('@dmzx_notifyadm...') #1 /web/htdocs/www.openresource.it/home/phpbb/vendor/twig/twig/lib/Twig/Loader/Filesystem.php(138): phpbb\template\twig\loader->findTemplate('@dmzx_notifyadm...') #2 /web/htdocs/www.openresource.it/home/phpbb/vendor/twig/twig/lib/Twig/Environment.php(266): Twig_Loader_Filesystem->getCacheKey('@dmzx_notifyadm...') #3 /web/htdocs/www.openresource.it/home/phpbb/vendor/twig/twig/lib/Twig/Environment.php(324): Twig_Environment->getTemplateClass('@dmzx_notifyadm...', NULL) #4 /web/htdocs/www.openresource.it/home/phpbb/phpbb/template/twig/environment.php(166): Twig_Environment->loadTemplate('@dmzx_notifyadm...', NULL) #5 /web/h in /web/htdocs/www.openresource.it/home/phpbb/vendor/twig/twig/lib/Twig/Loader/Filesystem.php on line 195
Re: admin notify
Check if you default language is other then EN in the folder language and change it to the correct language.
moffacostanzo
Re: admin notify
moffacostanzo
Re: admin notify
Funtion thie ext with 3.1.6
