3.2.x Extensions Database 3.2 / 3.3 ⇒ Form Maker/Creator 3.2.x
HarveyWNvm
Re: Form Maker/Creator 3.2.x
Will it go for free hosting?
Milunice259
- New user
Any chance for phpbb 3.3.0?
Hippie459MN
- Donator
Its working here on 3.3.0 but you need to fix a file.
Open dmzx/formcreator/config/tables.yml
Find:
parameters:
dmzx.formcreator.table.formcreator: %core.table_prefix%form_makerCode: Select all
parameters:
dmzx.formcreator.table.formcreator: '%core.table_prefix%form_maker'"I went outside once. The graphics sucked but the game play was ok."
kstory
- New user
Not sure if anyone is still having issues with text not displaying in the text box once it has posted, but I figured out a temporary fix.
Open the listener.php file and find the line case ‘text box’ for the textarea input. Add before the closing tag for textarea.
This will add an extra space at the beginning of the output for all textarea input when there is and is not text within the text box. The extra space isn’t that noticeable if you’re not starring at it! Lol
scotty63
- New user
Hi.
Please tell me how to add paired fields? For example Question / Answer.
So that the question and answer during publication are displayed in parallel (not under each other).
Like this:
Like this:
Jorup16
Is there any Spanish translation for this Ext?
TazDevilBZH
Here is the french translation for this marvelous extension :
stone23
Will the development of this extension continue?
Yes but all needs time, I have allot on going now.
mayhemkrew
- New user
Is there a way to list the form checkboxes vertically instead of inline? When you have multiple rows, it gets confusing of what checkbox goes to what.
undergroundpost
- New user
Thank you! Any chance to add ability search and filter results according to forms value? (for example: form "year" and filter search by years 1990-2000), or search text in specific form only?mayhemkrew wrote: 24 Dec 2020, 17:24 Is there a way to list the form checkboxes vertically instead of inline? When you have multiple rows, it gets confusing of what checkbox goes to what.
I will update this extension soon, but need to check your request.undergroundpost wrote: 06 Jan 2021, 09:44Thank you! Any chance to add ability search and filter results according to forms value? (for example: form "year" and filter search by years 1990-2000), or search text in specific form only?mayhemkrew wrote: 24 Dec 2020, 17:24 Is there a way to list the form checkboxes vertically instead of inline? When you have multiple rows, it gets confusing of what checkbox goes to what.
HoodieWeather
This work on 3.3.3board?
Love to see a way to upload images and then have it either center, to the left, or right.
Also, love to see a .nfo viewer. Upload .nfo files and it will spit them out as pictures when someone clicks on 'view nfo'
HoodieWeather
How do you cut down on the table boxes? they are rather long after posting. Is there a way to make them smaller.
see image.
see image.
HoodieWeather
If there's a way to cut down on the text boxes that would be awesome.
