I am using this function which you describe. It works great.forer wrote: 26 Aug 2018, 18:42+1Hippie459MN wrote: 11 Jan 2017, 01:04 Very nice! Is there anyway to make the new post default to the form so one wouldnt have to click the button?
Thanks for that great extension!
An ACP option so that the form is used by default on a specific forum (being the form the only way to write the first post) would be perfect.
3.2.x Extensions Database 3.2 / 3.3 ⇒ Form Maker/Creator 3.2.x
Re: Form Maker/Creator 3.2.x
imanonuser
Hello mf.
Thank you so much for the Form Maker/Creator
Can you tell me pls, how i can do it? (this is an example)
Or have another way?
Pls..
Pls..
forer
Could you please explain how do you do it? TY!
jan_2017 wrote: 16 Sep 2018, 09:55I am using this function which you describe. It works great.forer wrote: 26 Aug 2018, 18:42+1Hippie459MN wrote: 11 Jan 2017, 01:04 Very nice! Is there anyway to make the new post default to the form so one wouldnt have to click the button?
Hippie459MN
- Donator
"I went outside once. The graphics sucked but the game play was ok."
forer
forer
Hi again, I've deleted the "display:none;" and purged cache but I'm getting both, the "form mode" and the "normal mode", please see the image:
Any ideas?
Thanks!
Any ideas?
Thanks!
imanonuser
Clear cash your google chrome.. I have this problems many times
forer wrote: 08 Nov 2018, 12:03 Hi again, I've deleted the "display:none;" and purged cache but I'm getting both, the "form mode" and the "normal mode", please see the image:
Any ideas?
Thanks!
forer
Thanks imanonuser, but still not working, even using other browser on other PC and after cleaning the forum cache.
Any other idea please?
imanonuser wrote: 13 Nov 2018, 16:42 Clear cash your google chrome.. I have this problems many times
Muse
This is a great extension and it's exactly what I've been looking for.
I'd love to see the option to add headers, BBCode formatting (or CSS class styles or HTML/CSS formatting) to the output, or even a way to section off parts of the output so that it's got a header or two and an hr tag between or whatever ... part of the form outputs to a blue box and the other half a yellow box for example).
If adding a customization to the form layout and the form output is possible, I'll happily pay for a customized version of this extension! I know when I'm over my head in code and would love to compensate someone more skilled than myself fairly.
Let me know if this could be a thing!
warcelo
- New user
Hello, Im having problems when using this with the latest version of phpBB 3.2.7
Every time I click on the Full Editor and Preview instead on the quick reply I get an error message like this one:
[phpBB Debug] PHP Warning: in file [ROOT]/vendor/s9e/text-formatter/src/Renderer.php on line 20: DOMDocument::loadXML(): Empty string supplied as input
TWEagle
Is it possible to when you have made a topic from this form maker to make an announcement that there is a new topic from this form?
I am using the form maker to get some new "programs"from office in a nice template but we want to get the users know that there is a new "program"available for them
scheccia
I have this error on forum that formMaker isn't active
i see that when i click on reply, the extension try to make a preview.
[phpBB Debug] PHP Notice: in file [ROOT]/ext/dmzx/formcreator/event/listener.php on line 395: Undefined variable: fieldcontents
[phpBB Debug] PHP Notice: in file [ROOT]/vendor/s9e/text-formatter/src/Renderer.php on line 23: Trying to get property 'message' of non-object-
scheccia
I found how fix (seems to work)
listener.php
listener.php
if ($message === '')
if ($mode <>'reply'){ //mod
$message = $this->grab_form_data($forum_id);
foreach ($files as $key => $name)
$message_parser->parse_attachments($key, $mode, $forum_id, $submit, $preview, $refresh);
$message_parser->message = $message;
$post_data = $message_parser->message;
br0nks
Hej! great ext!
i have problem, always it says To small charakters in your message. and than he delete all my putted data.
what can be that problem?
nirolp
- New user
I'm sorry for my bad English. However, I have the following problem:
If I replace the place with the '_' with ' ' in line 324 in the listener.php, then I will not see any more inhald of the form in the thread.
Kann mir jemand helfen?
