3.1.x Extensions Database 3.1 / 3.2 ⇒ Custom Header Logo
Fast_Eddie
Re: Custom Header Logo
acp / board settings / site name & description
Short of leaving these 2 lines blank is there a way to suppress their display in the header? When you leave the site name blank the board name is not sent in the new user e-mail after registration.
rogerio24
Any update about it?rogerio24 wrote: 09 Jun 2016, 03:42we are about to fix it. We are closerogerio24 wrote: 08 Jun 2016, 23:41Hi Good Day. Thanks for your answer. Let me configure and I will let you know I think we are about to fix it :)dmzx wrote: 08 Jun 2016, 22:39Is your Enable URL Rewriting on?rogerio24 wrote: 08 Jun 2016, 08:04I will record a video and I will show you that any tips provided by you work. Don't worry.dmzx wrote: 07 Jun 2016, 22:41 On here its a mix between Custom Header Logo & cssmagic
To keep it simple add for example every flag in Custom Header Logo like: app/flags/16 and next flag app/flags/17 ect..
So every flag new line...
The problem is that extension does not recognize this kind of situation or path app.php/flags/
let me check first
I just enable URL Rewriting as you told me. The app.php does not appears anymore
Look the video. When I go to some one flags section it is not working. But in general flags section it works
https://www.youtube.com/watch?v=K46_MC3O5B4
Thanks!
rogerio24
I do not know why you are saying artodia. In my forum I'm not using artodia. @dmzx Could you help me please? dmzx
x8BiTw0LFx
https://www.artodia.com/phpbb-styles/black2/
TWEagle
Hey dmzx,
I have seen that a collegue of us (member of forum) has already asked but there wasn't an answer
how does it works for pbwow/pbtech?
Fast_Eddie
Is there a work around to suppress board name and and short text from acp/board settings ?
jucaes
Hello I use https://www.phpbb.com/community/app.php ... l_edition/
whit phpbb 3.1.10
but didnt show any custom Header Background and Logo
Can you help me?
THANKS!!!!
whit phpbb 3.1.10
Can you help me?
THANKS!!!!
If I have some time I will install that style to test.jucaes wrote: 05 Jan 2017, 00:42 Hello I use https://www.phpbb.com/community/app.php ... l_edition/
whit phpbb 3.1.10
Can you help me?
THANKS!!!!
RTI kartname
It runs on phpBB 3.2.0?
No will post the 3.2.x version soon.
bcurran3
You can make do with david63/sitelogo until dmzx updates his extension.
Hello.
i use phpbb 3.1.10 with prosilver
Nice extension .... very good work
but...mchat window and Blog does not work
patch : Blog , mchat
query: * , /*
acq cache clear.....yes
no Background appears
all other settings work fine
[ Post made via Android ]
query: * , /*
