3.1 & 3.2 Extensions Database 3.1 / 3.2Animated PM Notification
rammstein
Re: Animated PM Notification
Post by rammstein »
Hello Sniper
thank you for your answer I just made the test avartar he is too big and his must be left we see it and the center
thank you
That was the code from the header navbar. That avatar should be as small as that one.
I did not test any of that of course. I'll try the codes and see what will work and get back to you.
rammstein
Post by rammstein »
OK thank you it is nice
rammstein
Post by rammstein »
how can I change the color of the message counter at home I have a red circle with the white number I would like to put the number in red and the other in green
This red background with white text is prosilver's default badge colors. It is not controlled by the extension.
I use blue background with white text... or red background with white text.
In my style's colours.css I changed the colors of the .badge class.
.badge {
	background-color: #0D4863 !important;
	color: #FFFFFF !important;
.badge-new {
	background-color: #D31141 !important;
But I guess you could place that code in the anipmnotify.css and use the colors you want.
rammstein
Post by rammstein »
Ok thank you
