Funwave123
Re:
Post by Funwave123 »
Hey, thanks for that Mod over Years.
But I have update the Forum from 3.2 to 3.3.5 (wait a bit before I - maybe - use 3.3.7).
Now I get massive trouble:
API Key (yt api) and Settings:
Result...
Website-Crash:
How can I fix that problem ?
Ther Api-Key is with the (bad) new Google-api Center created - cant create another one (or?).
Thanks in advance
Re: Youtube Videos Gallery
Does the video link have emojis in it ?
faroud
Post by faroud »
Yes api key for youtube here
https://console.cloud.google.com/
:tumbsyes:
RayTek
Post by RayTek »
Hi I have issue with login from video page..
Also profile alignment issue using tatiana5/profilesideswitcher
Any help is much apprenticed.
Xxxbennyxxx
Post by Xxxbennyxxx »
The css code below gives problems with other extensions that use the same element.
Is there a way to get around this?
a {
    display: inline;
Xxxbennyxxx
Been looking for a long time, but found a solution.
video_cat.html:
					<a href="{{ video.U_VIEW_VIDEO }}" title="{{ video.VIDEO_TITLE }}"style="display:inline"><img src="{{ video.VIDEO_THUMBNAIL }}" alt="{{ video.VIDEO_TITLE }}"style="display:inline"></a>
video_search.html:
				<a href="{{ video.U_VIEW_VIDEO }}" title="{{ video.VIDEO_TITLE }}"style="display:inline"><img src="{{ video.VIDEO_THUMBNAIL }}" alt="{{ video.VIDEO_TITLE }}" style="display:inline"></a>
video_body.html:
Xxxbennyxxx
Just a quick question: On my style, the profiles are on the left by default. But this makes that in the video body the profile of the poster is placed down (below video)
If I add the following code to the css it works fine.
But is this the right way or is there a better piece of css
.postbody  {
  float: right;
Thats the right way.
Prosk8er
Post by Prosk8er »
Hi i'm having a issue with the extension as is another user from phpbb
i opened a github issue wont let me post link i'll copy what i wrote
[phpBB Debug] PHP Warning: in file [ROOT]/ext/dmzx/youtubegallery/controller/admin_controller.php on line 329: Trying to access array offset on value of type null
error appears when i hit resynchronise for video titles
video titles aren't working its just blank another user on phpbb is having same issue
phpBB 3.3.10
php 8.0.25
is anyone else getting this?
Has the video name got emoji's in the tittle ?
Prosk8er wrote: 11 Feb 2023, 01:54 hi i'm having a issue with the extension as is another user from phpbb
phpBB 3.3.10
php 8.0.25
Working fine on my site.. Whoops not on 3.3.10 tho.
Prosk8er
Post by Prosk8er »
martin wrote: 11 Feb 2023, 03:33 Has the video name got emoji's in the tittle ?
it does tried a couple more without and same exact result
Pls post a link here that gives you the error.
Prosk8er
Post by Prosk8er »
Wont let me post links here's the video ids
qhwbBA9uqh0
_JZom_gVfuw
