3.1.x Extensions Database 3.1 / 3.2Custom Header Logo
rogerio24
    Linux Firefox
Re: Custom Header Logo
Post by rogerio24 »
dmzx wrote: 06 Jun 2016, 18:25 So at Page Query you set the * :question:
And cleared the cache?
Yes I did it as you told me. Look this video
https://www.youtube.com/watch?v=YWRNrFBzUv0
rogerio24
    Linux Firefox
Post by rogerio24 »
Any update?
Thanks!
8 given 1
Ok for main flag page use app/flags with image, see picture below.
Use for all others like line 2.
This means all counties get a line, I did it different here and us cssmagic extension to add the logo 1 time.
rogerio24
    Linux Firefox
Post by rogerio24 »
dmzx wrote: 07 Jun 2016, 18:23 Ok for main flag page use app/flags with image, see picture below.
Thanks for your reply
I did not understand one thing, when you say "I did it different here and us cssmagic extension to add the logo 1 time." Yes I know that cssmagic is a extnsion but I did not understand what you mean
8 given 1
rogerio24 wrote: 07 Jun 2016, 18:55 [ Yes I know that cssmagic is a extnsion but I did not understand what you mean
I added in cssmagic css file:
.site_logo {
        background-image: url("./images/dmzx-web_light.png");
	background-repeat: no-repeat;
	display: inline-block;
	width: 600px;
	height: 52px;
try that with your logo.
rogerio24
    Linux Firefox
Post by rogerio24 »
I have configured all your tips but it did not work. :( Don't worry. Do you know about another extension related with flags? I have installed this in my forum National Flags 2.0.0
8 given 1
On here its a mix between Custom Header Logo & cssmagic
To keep it simple add for example every flag in Custom Header Logo like: app/flags/16 and next flag app/flags/17 ect..
So every flag new line...
rogerio24
    Linux Firefox
Post by rogerio24 »
dmzx wrote: 07 Jun 2016, 22:41 On here its a mix between Custom Header Logo & cssmagic
I will record a video and I will show you that any tips provided by you work. Don't worry.
The problem is that extension does not recognize this kind of situation or path app.php/flags/
edited
video recorded
https://www.youtube.com/watch?v=PTHpUFQcMmk
Fast_Eddie
Post by Fast_Eddie »
Hello Dmzx,
I tried using this ext. on a new board I'm setting up , using the style '' ne-blackgreen '' https://www.phpbb.com/community/viewtop ... &t=2348621 And it works ok. But it's stacking the logo on top of the header and moves all navbar links into the quicklink menu.
Would there be a fix for this?
Here is a screen cap so you can see.....
:beers: Retirement 2024!
8 given 1
Fast_Eddie wrote: 08 Jun 2016, 19:30 Hello Dmzx,
Can you comment out this part in ne-blackgreen/theme/stylesheet.css
.headerbar {
  height: 100px;
Clear cache and check again.
Fast_Eddie
:tumbsyes: that fixed it. I didnt think to look at the stylesheet.css
8 given 1
rogerio24 wrote: 08 Jun 2016, 08:04
Is your Enable URL Rewriting on?
rogerio24
    Linux Firefox
Post by rogerio24 »
dmzx wrote: 08 Jun 2016, 22:39
Hi Good Day. Thanks for your answer. Let me configure and I will let you know I think we are about to fix it :) :tumbsyes: let me check first
rogerio24
    Linux Firefox
Post by rogerio24 »
rogerio24 wrote: 08 Jun 2016, 23:41
we are about to fix it. We are close :D
I just enable URL Rewriting as you told me. The app.php does not appears anymore :D
Look the video. When I go to some one flags section it is not working. But in general flags section it works
https://www.youtube.com/watch?v=K46_MC3O5B4
rogerio24
    Linux Firefox
Post by rogerio24 »
Have you seen it?
