3.2 & 3.3 Extensions Database 3.2 / 3.3 ⇒ Ultimate Points Extension
Yemmy
Re: Ultimate Points Extension
Lovely extension the best ever.
Please can you add daily logins point and repost/comments point
odpro
- New user
Good afternoon. A very great addition, thanks! Interested in the issue of spending points, namely, it is planned that the information will be hidden and the creator of the topic indicates how many points will be deducted when opening the content, how can this be implemented? Thanks in advance.
Yemmy
Great extension ever, I love it please keep the creativity on.
Please I want to ask if there is an option for in the extension that allows daily login points for members.
kangeroe
But at point settings
a white page
other works
a white page
other works
I avoid this ext myself but i'm sure dmzx will answer when he comes online.
kangeroe
I think this is an older extension?
to my other site is completely
another extension that works perfectly
Dont think do some checks to find out.
kangeroe
I downloaded the wrong version
now have the good one and it works perfectly
regards
regards
odpro
- New user
Hello i want stimulate actively on forum, so very goog idea of earning coins but need upgrade how to spend them.
For example user make post and add hide information whith price of point, and another user can buy this info and make unhide by spending coins what he earned by new post etc. What encourages users to constantly add new information and spend points to get existing. If possible im ready donat for this update.
kangeroe
Doesn't everyone get points?
every time you post
in a topic?
you have to set this in your acp panel
regards
every time you post
in a topic?
regards
roiebh
- New user
Could you please add an option to "pay to thank" with integration with this ext:
Thank for post
phpbb com/customise/db/extension/thanks_for_posts_2/
Thank you
Thank for post
Thank you
seacoast
Upgrading 1.2.2 to 1.2.4 on phpbb 3.2.1.
Is all I need to do is delete the UP folder, upload the new, and enable?
UPDATE: All set. It's been a while since I upgraded an ext. Figured it out.
roiebh
- New user
Worked for me :)seacoast wrote: 03 Apr 2020, 00:20 Upgrading 1.2.2 to 1.2.4 on phpbb 3.2.1.
umi
Someone could translate this ext to spanish?
Regards
Regards
Merlino
Hello!
If I see who is online and someone is inside at ultimate points I see this, is it normal or should I read "Ultimate Points" ? Tnx
