Re: Image Upload
[phpBB Debug] PHP Warning: in file [ROOT]/ext/dmzx/imageupload/controller/admin_controller.php on line 211: getimagesize(./../ext/dmzx/imageupload/files/d50604dd62b60c485bc3459f71e93c68.png): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_acp.php on line 137: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3365)
i suspect that in ACP
Re: Image Upload
Missing image the file is stored in database but not on the server.
Re: Image Upload
martin wrote: 13 Sep 2019, 13:11 Missing image the file is stored in database but not on the server.
i fix that but now
[phpBB Debug] PHP Warning: in file [ROOT]/ext/dmzx/imageupload/event/listener.php on line 266: getimagesize(./ext/dmzx/imageupload/files/d50604dd62b60c485bc3459f71e93c68.png): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4628: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3365)
or it's the same issue?
Re: Image Upload
Re: Image Upload
martin wrote: 13 Sep 2019, 13:21 /ext/dmzx/imageupload/files/d50604dd62b60c485bc3459f71e93c68.png): failed to open stream: No such file or directory
urgh i disable all extension,but still see this error
Re: Image Upload
Delete data you dont have them images on your server but are in the database unistall and delete data.
Read the error it tells you what is wrong.
Re: Image Upload
I think it was style issue..urgh i hate style issue.. :guns:
Re: Image Upload
Nope the images was missing look at the error message.
Re: Image Upload
Re: Image Upload
Which file need to change to set new size of mb upload?
Re: Image Upload
Can set size in acp but depends on your limits in php.ini file.
Re: Image Upload
martin wrote: 17 Nov 2019, 04:03 Can set size in acp but depends on your limits in php.ini file.
yea,i know but want to change limit in php,ini file
g0lang
    Linux Firefox
Re: Image Upload
Post by g0lang »
Thanks for the wonderfull extension.
I made some update to the code, would you merge my PR in github ?
https://github-dot-com/dmzx/Image-Upload/pull/7
1. nginx compatible
rename "files" dir to "img-files" since we have nginx rules which deny access to files dir
(please ref to
https://github-dot-com/phpbb/area51-phpbb3/blob/master/phpBB/docs/nginx.sample.conf#L65
2. files saved in sub-dir like img-files/user_id/xx/xx/foooo.jpg
3. optimized some code
Re: Image Upload
g0lang wrote: 21 Nov 2019, 08:05 thanks for the wonderfull extension.
1. nginx compatible
(please ref to
I will take a look at the PR, first impression its a good idea. :thumbup:
g0lang
    Linux Firefox
Re: Image Upload
Post by g0lang »
dmzx wrote: 21 Nov 2019, 08:53 Did check the PR, the folder is not deleted when you delete the image. Did not have time to check the rmdir but will look into it.
Did you want to keep the folders?
I think ti's too heavy for removing the sub-dir when user delete images.
maybe a better solution is to create a cron job to do the cleaning.
