3.2 & 3.3 Extensions Database 3.1 / 3.2Mobile Device
Re: Mobile Device
:w00t:
Edit: Wow it works!
Re: Mobile Device
Sniper_E works perfectimo
[ Post made via Samsung Galaxy S4 ] Image
Bullseye
Re: Mobile Device
Post by Bullseye »
Installed!
Edit: I have someone signed in using a Samsung SM-G900F, but it's not showing up, but it's working perfect for the Galaxy Ace 4 :eusa_dance:
[ Post made via Half Life 3] Image
Re: Mobile Device
Just add it in on this line: elseif (preg_match('/SM-G900P|SM-G900F/i',$user_agent))
Samsung Galaxy S5 is already in the list, just not his model.
Bullseye
Re: Mobile Device
Post by Bullseye »
In listener.php?
Re: Mobile Device
Yes in the event/listener.php on line 365
[ Post made via Carrot Phone ] Image
Re: Mobile Device
Test
[ Post made via Shithead ] Image
Bullseye
Re: Mobile Device
Post by Bullseye »
Thanks Sniper :eyes2:
I prefer the more conventional way of communication.... anyway.. I see it's been added to the list! :eusa_dance: :eusa_dance: :eusa_dance:
[ Post made via Bean Can ] Image
Bullseye
Re: Mobile Device
Post by Bullseye »
Sniper_E wrote:Yes in the event/listener.php on line 365
I'm using notepad ++ the nexus is on that line & I want to add Samsung SM-G900F, would I need to edit it so it looked like this:
elseif (preg_match('/KTU84P|KTU84P/i|SMG900F',$user_agent))
Re: Mobile Device
Bullseye wrote:I'm using notepad ++ the nexus is on that line & I want to add Samsung SM-G900F, would I need to edit it so it looked like this:
Why did I have 2 KTU84P listed in that line? That was a copy/paste error.
That line should have looked like this at first: elseif (preg_match('/KTU84P/i',$user_agent))
You would have needed to add it in like this... elseif (preg_match('/KTU84P|SMG900F/i',$user_agent))
--- But you are trying to add that to the wrong line. Do not add it to that line. --- I told you the wrong line.
Bullseye wrote:I have someone signed in using a Samsung SM-G900F, but it's not showing up.
I put the number SMG900F in my Google search bar and it pulled up a Samsung Galaxy S5
So you would find that case...
                elseif (preg_match('/SM-G900P/i',$user_agent))
                    $status = 'Samsung Galaxy S5';
To add that in, this line elseif (preg_match('/SM-G900P/i',$user_agent))
would be changed to elseif (preg_match('/SM-G900P|SM-G900F/i',$user_agent))
Bullseye
Re: Mobile Device
Post by Bullseye »
Sorry yes I think it was a copy & paste error :oops:
Ok, I have made the edit, I'll try it out tomorrow & I'll let you know how I get on :eusa_dance: :w00t:
Another edit..
And it works :eyes2: :eyes2: :eusa_dance: :eusa_dance:
Bullseye
Re: Mobile Device
Post by Bullseye »
Noticed something odd, my Samsung Galaxy Tab 3 comes up as a note 3... :eyes2:
Re: Mobile Device
Shop sold you a dud then :rolling:
Bullseye
Re: Mobile Device
Post by Bullseye »
What are you like...... :rolling:
[ Post made via Samsung Galaxy Note 3 ] Image
Re: Mobile Device
Bullseye wrote:Noticed something odd, my Samsung Galaxy Tab 3 comes up as a note 3... :eyes2:
We may have stuck your device in the wrong case.
				elseif (preg_match('/SM-N9005|SM-P600/i',$user_agent))
					$status = 'Samsung Galaxy Note 3';
Which one of those numbers is in your user agent? SM-N9005 or SM-P600
It will need to be moved into this case...
				elseif (preg_match('/SM-T310/i',$user_agent))
					$status = 'Samsung Galaxy Tab 3';
