3.2 & 3.3 Extensions Database 3.2 / 3.3Download System
Driver80
Re: Download System
Post by Driver80 »
Does this extension only work with files on ftp? and a link to another site can’t insert a file?
Re: Download System
You can ftp the file and link to the name or upload the zip from the acp.
No if you want the link from an external site it was not made for that as any one could link to a zip from another site when they should not be.
BarTender
Re: Total Downloads Extension
Post by BarTender »
:coffee: good evening I download your extention it works but I do not have the image
at your home
home
BarTender wrote: 05 Jun 2020, 20:14 :coffee: good evening I download your extention it works but I do not have the image
at your home
home
check if default_dl.png is in images/downloadsystem folder.
BarTender
Re: Download System
Post by BarTender »
It's in the folder I don't see image
Re: Download System
BarTender wrote: 06 Jun 2020, 14:02 it's in the folder I don't see image
pm me the url of your board.
Re: Download System
Image link dont look right to me has port number in it.
Hensyr Wolf
    Ubuntu Firefox
Re: Download System
Post by Hensyr Wolf »
I create a whole new forum and use your extensions gratefully. :thumbup: :eusa_dance:
But I wonder if I can also offer ISO files to my members.
These iso files are about 3 to 4 GB. :yikes: :w00t:
Can you tell me how to do this if possible. :wink: :tumbsyes:
Re: Download System
Hensyr Wolf wrote: 13 Jun 2020, 04:43 But I wonder if I can also offer ISO files to my members.
you can allow iso files to attach to ur topic from ACP--->extensions
Hensyr Wolf
    Ubuntu Firefox
Re: Download System
Ok I'm probably not going to be able to use the extension if I want to make 4 Gig available.
I have Versio as host provider and they only allow 1 Gig in php settings.
Re: Download System
Hensyr Wolf wrote: 13 Jun 2020, 10:25 Ok I'm probably not going to be able to use the extension if I want to make 4 Gig available.
Ask your host to adjust the setting, maybe they will..
Hensyr Wolf
    Ubuntu Firefox
Re: Download System
Hi dear dmzx, I will certainly ask if they want to increase the limit.
I will let you know here if they allow it.
This would be really interesting. :tumbsyes:
wads24
Re: Download System
Post by wads24 »
dmzx wrote: 13 May 2019, 13:54 Check you database dm_eds table.
Check download_desc and if there are descriptions starting without < add them to the fields like:
<t>Latest version</t>
so starting with a <t> some text </t>
I did this and still getting error...
Cannot load XML: Start tag expected, '<' not found
wads24
Re: Download System
Post by wads24 »
wads24 wrote: 12 Aug 2020, 01:55
I figured it out... I had to add the <t>Latest version</t> to category descriptions also.,.
I did notice that the upload link is missing now. Any ideas?
edsonqr
Re: Download System
Post by edsonqr »
first, congratulations on this extension. Im experiencing a problem with uploading files. If I do it through ACp, after the upload is finished, a red window appears saying "You have to enter a file, which belongs to your upload!".
If I upload via the user upload option, after uploading the window simply returns and the file is not there either.
The size of this file is 60Mb and the upload time is 58 seconds.
My phpBB is 3.31, the extension is 1.15 and my php.ini has a time of 2 minutes and a limit of 100Mb
I appreciate the help
Sorry my English
