3.2 & 3.3 Extensions Database 3.2 / 3.3 ⇒ Download System
Re: Download System
no,i mean just a line like description, under description tab add language
Mannix
Re: Download System
Hi I would like to ask if it's possible to display subcategories in the parent category the same way subforums are handled in phpbb?? Right now when you visit parent category that has subcategories it says "There are no download". It may be a bit misleading for some users so adding a list of subcategories there would be a good idea imo.
Hamidouki-dz
Re: Download System
Since i updated my extension i have only one single file is being downloadable between all other files i have uploaded, its like that one perticular is replacing them all when i hit any files download button .
I tryed to delete and reinstall it all annd still the same problem
Hamidouki-dz
Re: Download System
I use the extension on my new forum 3.2.8
php: 7.2
problem: the download works for only one file, but the other files are present in the directory: ext / dmzx / ... / files / but I get only the first file.
I do not understand where is the problem?
forum
ACCOUNT INFO REMOVED PLS DONT POST ACCOUNTS AND PASSWORDS ON AN OPEN FORUM US THE PM SYSTEM.
php: 7.2
forum
Re: Download System
You have a js error downloadsystem.js?assets_version=198:69 Uncaught TypeError: e.preventDefault is not a function
I would say its a conflict with another ext you have installed.
Hamidouki-dz
Re: Download System
do I have to remove the installs lately.martin wrote: 01 Dec 2019, 18:13 You have a js error downloadsystem.js?assets_version=198:69 Uncaught TypeError: e.preventDefault is not a function
it means to know which!
- Donator
Re: Download System
Don't Remove Any ext...
Just disable the other ext 1 at a time clear cache then retry download system until you find the other ext that is conflicting
Hamidouki-dz
Re: Download System
I tried but are no mistake.
it's hard for me to analyze and find the mistake
- Donator
Re: Download System
I am sorry I don't know then :(
Re: Download System
Thanks for reporting, must be solved in v1.1.3Hamidouki-dz wrote: 01 Dec 2019, 01:55 Hello
Hamidouki-dz
Re: Download System
Everything is working fine now....you are amazing mate ....all goood ....all great
joshqute
Re: Download System
Download System does not work (SQL error) after creating categories, on Localhost ... Download System v1.1.4, PhpBB v3.2.8, mySQL 5.4
Re: Download System
Can you post the error?joshqute wrote: 10 Jan 2020, 08:04 Download System does not work (SQL error) after creating categories, on Localhost ... Download System v1.1.4, PhpBB v3.2.8, mySQL 5.4
