3.1.x Extensions Database 3.1 / 3.2[RC] Smilie Signs
Puchahawa
Re: [RC] Smilie Signs
Post by Puchahawa »
Or not! :rolling: At least in my test. I'm running php 5.5.12 Apache 2.4.9
Used signs version 1.0.11. It loads fine and works fine except when the post is created it's missing the smilie. Same issue we came upon due to your site addy in the html repl code. Only issue is, it's the correct info. :wtf:
Took a snap of the source code of the page figuring you might get something out of it. Only thing I see is when it gets to the image addy there is no name for the image shown in the code. Tried using fright and blind signs
EDIT: took the same info on 3.1.10 board and signs version 1.0.11 You can see the smilie name in the url.
EDIT 15Jan17: just triend again using 1.0.11 on a 3.2 gold board and they work fine. :rolling:
Puchahawa
Post by Puchahawa »
HI Sniper. Was just talking to a few people about the signs ext on the .com site and null came across this interesting expression when using the ext on 3.2.0 Shows up in the registration "terms" page. :wtf: Button works fine just some funky wording. The extension works fine in prosiver for me outside of this.
This is the code for the button from view page source.
<div class="panel">
		<div class="inner">
		<fieldset class="submit-buttons">
						<input type="submit" name="agreed" id="agreed" value="[sign=agree]text[/sign]" class="button1" />&nbsp;
			<input type="submit" name="not_agreed" value="I do not agree to these terms" class="button2" />
						<input type="hidden" name="change_lang" value="" />
			<input type="hidden" name="creation_time" value="1484529154" />
<input type="hidden" name="form_token" value="bb36e367bdb4d7fc3fceb667f7ced649731c2ceb" />
		</fieldset>
		</div>
	</div>
Looking at it in the developers tools of chrome
Ah that is a new one found. The language file names for that one will have to be changed to "agrees" and in the template also. I'll have to get home to look at that. I have 3.2.0 installed now so I'll get the fix for that shortly.
Puchahawa
Post by Puchahawa »
Hey sniper, just thought you may want to know that the registration button is funky in 3.1.10 also. Never thought to look at it before. running 1.0.11 version of signs. My live board (3.1.10) is running 1.0.7 of signs and the button issue isn't there.
Fast_Eddie
Post by Fast_Eddie »
Puchahawa wrote: 16 Jan 2017, 02:22 HI Sniper. Was just talking to a few people about the signs ext on the .com site and null came across this interesting expression when using the ext on 3.2.0 Shows up in the registration "terms" page. :wtf: Button works fine just some funky wording. The extension works fine in prosiver for me outside of this.
<div class="panel">
		<div class="inner">
		</fieldset>
		</div>
	</div>
Same issue for me on 3.1.10
:beers: Retirement 2024!
Yes the agree needs to be changed to agrees. They had the agree class/language first.
smiliesigns/language/en/common.css
'AGREES_TITLE' => 'Agree'
Lower down
'AGREES' => '[sign=agrees]text[/sign]
styles/all/template/smiliessigns_posting_editor_button.html
line 16
[sign=agrees] (to the right) [L_AGREES_TITLE]
Lowe down line 143
[L_AGREES] (to the right) [L_AGREES_TITLE]
.com has a few changes they pointed out I will have to fix. I'll fix that also..
moffacostanzo
Post by moffacostanzo »
I have a problem with a friends
Puchahawa
Post by Puchahawa »
Jrolson just came out with a version of aero for 3.2 so doing some testing. Everything is working correctly. I know, amazing. :w00t:
running 3.2.0, signs 1.0.11 and abbc3 3.1.3. Did notice one minor edit. smiliesigns/style/aero/theme/smilie signs.css line 11 styles/aero_black/theme
aero_black vs aero black. need to clear browser cache to see the edit or the post doesn't show.
Will check it.
waltons73
Post by waltons73 »
HI Sniper,
I'm trying get your smilesign extention work on phpbb version 3.2 i install the extention but when i try used the smile sign the smilesign doesn't show only the text like this
 [sign=byebye]test[/sign]
and i read all the previous post on this thread and none seam to work and i'm trying it on my test board that does not have any bbcode listed any suggestions would be helpful thanks
only extentions i'm using is
EXTENSION NAME CURRENT VERSION OPTIONS ACTIONS
Enabled Extensions
Board Announcements 1.0.4 Details Disable
s9e/mediaembed 20170116 Details Disable
Smilie Signs 1.0.3 Details Disable
VigLink
Puchahawa
Post by Puchahawa »
Waltons73, if it's correct that your using version 1.0.3 that would be the problem. the current version is 1.0.11 You can download it on the first page of this topic. :D
waltons73
Post by waltons73 »
Thanks I got it working now
I've got one Problem.
my smilie sign looks like :wtf: :yikes:
i put in my prosilver color.css here.
where i took s mistake ??? :wall:
thanks
Ant
Post by Ant »
For me everything works fine for posts and mchat on the index page but mchat on the portal page doesnt show the smile like in this post [RC] Smilie Signs
I have tried fixing this myself but I can figure out what is wrong. I am using Talanos mchat portal extension.
Ant wrote: 24 Apr 2017, 17:52 for me everything works fine for posts and mchat on the index page but mchat on the portal page doesnt show the smile like in this post [RC] Smilie Signs
Is your forum/portal in root folder?
in smiliesigns_posting_editor_button.html the img looks to {ROOT_PATH} you can try to change it to {BOARD_URL}
