3.1.x Extensions Database 3.1 / 3.2 ⇒ Ultimate Points Extension
RTI kartname
Re: Ultimate Points Extension
Damn this is a big problem, if I knew it before not update, Phpbb 3.1.10 has many bugs, many extensions do not work, how can I go back? or go ahead with a new version 3.2.0 maybe ??
Clear your database from all tables, use the backup of your 3.1.9 database via phpMyAdmin. Delete all the phpBB files from your ftp (except /files, /images, /store, /ext, config.php and whatever you need to keep!) and reupload the fresh files of phpBB 3.1.9 instead.
For that you make backups every time you change something ;)
pikkio
Can someone please tell me with wich version of phpbb is compatible the ultimate points ext?
tnxx
tnxx
Kevicar
- Donator
I managed to correct the problem by handing the files to 3.1.9, then uninstalling Ultimate points completely, (with manual uninstall in the database) then reinstall!Kevicar wrote: 26 Dec 2016, 14:59I'm also waiting for these correction !Scanialady wrote: 26 Oct 2016, 17:03I am waiting for fixes, too. No need to update to this buggy phpBB 3.1.10 version. Too much important parts with bugs.Kinsman wrote: 25 Oct 2016, 22:01 Interesting, I can see at least three extensions updated their migration files to avoid the issue, so unsure of the way forward now beyone waiting for 3.1.11 to fix it.![]()
I can not successfully reinstall "Ultimate Points Extension" or other extensions, "Youtube Videos Gallery" on PhpBB 3.1.10.
If you have a solution, I'll take it !![]()
Once Ultimate point reinstalled, I have given the files of 3.1.10 ... and I wait for 3.1.11!
Same for "Youtube Videos Gallery" which reinstalled properly and everything works!
Happy New Year to all, and Thank you for your work!
silberfuchs
Could you please tell me / us how to do a manual deinstall of the extension in the database?
Thanks for your support!
[ Post made via iPhone ]
Joost
dmzx Have you a update from this extension to 3.2 please ?
Zoni
Installed now but when I go on PCA - > Extensions - Point Setting I get these error:
What I do?
What I do?
What version of phpBB do you use?Zoni wrote: 03 Feb 2017, 23:16 Installed now but when I go on PCA - > Extensions - Point Setting I get these error:
What I do?![]()
Zoni
Version phpBB: 3.1.8
Hosting: AlterVista
Hosting: AlterVista
Zoni
All work, thank you dmzx.
killfrenzy
Does anyone works Ultimate Extension V.1.1.8 in new board 3.2.
After updating this show error I tried to delete in DB modules ACP_POINTS
then activate again in ACP
show this error
show this error
- Androidcribs.com
- Androidcribs
trandoductin
I am on phpbb 3.2 btw, and i got the Ultimate Points 1.1.8 that works perfectly on 3.2.
I found the code that substracts points from user when they download a file in listener.php
I was able to modify it so that if user is logged in and has points it subtracts points from them and reward the poster with those points, otherwise it just lets users download without doing anything with points. This is what i want on my forum.
I have a question though.
How do i make (hack) it so that i can reward points when users follow/clicks on a link to the link poster?
I want to encourage good link posters with with points given when their links are followed.
